Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: sharping tungen
    West GA
    68
    Default sharping tungen
    I have a tig and I do not know how to use it but first thing is to sharpen the tungen. That is on mild steel, so now I would like to know if it is better to sharpen it on a grinder or on a belt sander. I am not doing a lot so I did not see the sense in buying a tungen sharper. I am just playing around with the tig. So all the help that I can get is good.
    JJE:
    Rather than post an answer to this, let me suggest that you go up to the top bar, search, and type tungsten sharpening in the box. You will find a large number of threads with a wealth of information to wade through.
    gate city virgina
    213
    Default well
    well my buddy at work sharpens his on a wheel grinder, and hes been doing it that way for about 6 years so however you want to do it i guess
    Hampton, Va.
    383
    I have been using an angle grinder to sharpen tungsten for over 35 years and I use the same wheel if I am welding stainless, carbon steel or anything else without any cross contamination.
    Hope this helps
    Wheelchair
    Apr 2007
    Ventura, California
    102
    Default Thoriated electrodes - warning
    In the event you are working with Thoriated electrodes (red band of color on the end), be aware they are mildly radioactive. Many welders like them because they work great. You could probably lick them all day long with your tounge and not suffer ill effects, but grind it into a fine dust (when you are sharpening it) and breathe it and you are asking for lung cancer.
    A welding instructor from a local high school recently died before his time, of lung cancer.
    I've been told the dust is so heavy that it will settle-out and you will never breathe it while grinding. Then why is there grinding dust on my respirator when I take it off? For me, I do NOT buy Thoriated electrodes. Lanthinated works fine for me. Costs a little more, but how much is our health worth?
    West GA
    68
    Default sharping tungsten
    thinks for the info. I just want to get all info that I can
    Indiana
    541
    I sharpen mine on the belt sander, seems to work better then the grinder, more control.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
    Olive Branch Ms
    129
    I've switched to all Lanth except in .040 (can't find it). I grind with a diamond shaping wheel off E-bay, ($45). Look under "lapidary materials" I think. I love it. It produces a good clean tip and a great arc.
    Webb's Welding and Repair LLC
    MM210 w/a 3035 spoolgun
    Spectrum 625
    Trialbazer 302 w/HF
    http://webbsweldingandrepair.com/home
    Noth Dakota
    505
    I have used a belt sander and a grinding wheel. Both work fine. I usually sharpen to 1 1/2 times the diameter or so.
    Northern CA
    90
    Chuck it into a cordless drill and sharpen it on a belt sander. Works great!
