    So. Cal
    335
    Thumbs up MM252 Takes on 1" Plate & Pipe
    Crank-it, pre-heat-it and spray it @ 90/10 gas mix. Got 3/4" penetration!
    TacMig
    We depend On:
    Burco/Koco | Onan | BobCat
    We belong to or support:
    American Welding Society
    The Welding Institute
    Anderson & Co. LLC
    Metal Cr
    afters
    694
    Quote Originally Posted by tacmig View Post
    TacMig
    How do you know you got 3/4" penetration? I kinda find that hard to believe possible out of that machine.
    Deltaville, VA
    2,241
    tacmig,
    Nice looking weld. Just curious how you determined you got 3/4" penetration.
    Assuming that you did get that penetration, was it really necessary, unless that's 3/4" wall pipe you're welding to the plate?
    So. Cal
    335
    Default How do I know..
    Quote Originally Posted by Engloid View Post
    I started with some 3/4" scrap. made one pass cold and just burned the bottom. Next pass was hot via: my O/A and spot burned the bottom about 80% and on second hot pass burned through!
    We depend On:
    Anderson & Co. LLC
    Metal Cr
    afters
    So. Cal
    335
    Default Better next time..
    tacmig,
    I should probably take more photos as I go, but usually don't think about it and the only reason I got photos of this is because I was surprised myself!. One of my guys took the 350 on a service call and got hung-up with extras. In any event, I had to build 4 gate posts out of 6" pipe @ 7/8" wall and 1" base plate (to be bolted to pre-poured form) and the next biggest thing I have is our new MM252. The weld would have been fine @ 1/2" but I was just ramping the 252 to see what she could do on 1". Also I ran a cold & hot test on scrap 3/4" and the hot run (Post O/A) dug in a ring at 3/4" on the 3/4" scrap. About as scientific as I get.
    We depend On:
    Anderson & Co. LLC
    Metal Cr
    afters
    Default how hot?
    how hot would you say you got the steel before you laid your beed to penetrate? are we talking glowing red.. or just screaming hot to the touch?
    So. Cal
    335
    Default Ahhhh?
    Quote Originally Posted by shott8283 View Post
    I heated both sides (plate) to about 3/4 screaming hot and the pipe at about 1/2 screaming hot. I wanted to go full screaming but I was afraid the neighbors might call the police. While we are the subject, do you have any idea what a metric sh!$ load weighs in LBS.? I think a U.S. Sh!$ load is equal to 3/4 of a ton. I know that Holy Sh!$ is weightless and Oh SH!$ is unmeasurable, but I can never figure out the metric thing.
    We depend On:
    Anderson & Co. LLC
    Metal Cr
    afters
    British Columbia
    162
    Talking perforated poop.................
    well holly #$%# ..........................lol
    a metric ton contains 1000 kg. or 2204 lbs. a metric ton of perforated sh@t might weigh less. holly/religious sh@t ............................now thats heavy.
    Syncro250DX Tigrunner
    Victor set
    Elite auto-helmet
    Dewalt Bench grinder
    Mastercraft miter saw
    Mac air tools
    Mac hand tools
    Toothbrush
    pencil
    toilet paper
    Jun 2006
    Killingworth,Ct.
    372
    Default My Guess
    PRICELESS!!!!!!!!!!!!eek:
