Results 11 to 20 of 25
Thread: Smoker's Done!
03-03-2010, 09:37 AM #11
Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
03-03-2010, 09:39 AM #12
The overall finish is a Dupont industrial coating. The fire box is sprayed with POR 15 silk, which has a temp rating of 1200 degrees. The POR 15 has only 1 coat and can be recoated after heating to 400 degrees.
Not going to fire it up, that's up to the winner. Couldn't raffle off a used product....Miller Syncrowave 200
130XP MIG
Spectrum 375
03-03-2010, 11:38 AM #13
- Dec 2009
- Northern California
- 179
nocheepgas,
Thank you for the reply.
I understand about not firing it up and leaving it up the the winner.
I have been watching your progress with great interest since I am assisting a friend with re-building his smoker that did not function well.
I am curious if you have created other smokers in a similar fashion and how the temperatures were across the grilles from the firebox to the stack area. This is one of the problems we are addressing with my friends unit since he had such a severe temperature drop from one end to the other.
Also, even though you lined the firebox with firebricks, I was concerned with the fact that you have an open face grille above and how that would affect the ability of the heat and smoke transfer into the actual smoker itself. I see this as a point where the needed heat escapes upwards instead of into the actual smoker.
Please don't misunderstand my questions, as I am not cutting up on your design or build. IT IS EXCELLENT!!!
I'm just trying to understand how you have built and overcome the problems that we see are happening with a similar (albet, Backyard), construction that is not working for us.
Any of your expertise and knowledge you are willing to share would be appreciated!
Again! AWESOME BUILD!!!
03-03-2010, 01:38 PM #14
- Oct 2007
- 2,949
Smoker
nocheep: That is an awesome job you did!
Hey, is that parked along Buffalo Soldier Trail? Looks pretty familiar
Dave"Bonne journe'e mes amis"
03-04-2010, 04:25 PM #15
I'm no expert, but did a fair amount of research and some discussion about smokers before taking this project on. As far as uneven heat, that will always be a problem if your smoke stacks are at or above cooking level. Ours were placed below the level of the cooking grates. As far as the fire brick, that was to help properly size the fire box as well as make it last longer. The fire box is always the first thing to burn out on these things, and lining it was to give it some additional longevity. As far as the grill, the lid on it seals pretty well and is intended to be used seperately from the smoker. You could close all the dampers to capture heat in the smoke box, fire off some steaks or burgers on the grill, then continue smoking in the smoke box. Or alternately when the rest of the meat is done, go ahead and grill at will.
The damper control between the fire and smoke boxes (unique to our build, as far as I know) should allow for some serious control of the heat issue.
Hope this helps.Miller Syncrowave 200
130XP MIG
Spectrum 375
03-04-2010, 04:27 PM #16
130XP MIG
Spectrum 375
03-04-2010, 10:19 PM #17
- Sep 2009
- 11
thats a nice rig man!
03-04-2010, 11:00 PM #18
- Dec 2009
- 179
YES!!!
Very good and excellent information!
You actually confirmed much of what basic physics I understood and why my friend was having so much problem with his!
I really think the key to what would make your unit much more efficient is the custom damper between the firebox and the smoker itself. I really like the dual stack exhaust design but was wondering if duals are overkill since you have a fairly good size pipe diameter already. But, since you can also control the outflow of both stacks, I don't really think it matters... Heck! It's really ***y Anyways!!!
Thanks again for the info and for sharing the build up!
Now please tell us again where we can buy the tickets???
03-05-2010, 09:13 AM #19
- Sep 2005
- Texas
- 279
Outstanding job on the pit and a wise choice of using fire brick in the firebox, when we replaced the firebox on our old pit we came up w/recycled fire brick, now the pit uses less wood to maintain the same cooking temp. and helps save the firebox from an early death.
Thanks again for sharing your project, good job
L*S
03-05-2010, 10:44 AM #20
- Oct 2007
- 2,949
Wilcox runs behind the "plaza" there at Coronado and Fry.
