Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
    1,258
    Default winch style bumper for 06 Ram
    I like the looks of them but not the price, so I decided to build my own.
    working out from the center
    welded the gussets before I couldn't get to them any more and added a brace just so the ears would somewhat hold their shape during fitup
    The one that dies with the most tools wins
    If it's worth having, it's worth working for
    1,258
    boxing it in
    getting there
    mocking up the outsides
    1,258
    with metal instead of cardboard:beerbang:
    drivers side done
    as I was cutting pieces for the drivers side I cut some for the passenger side also, so the second side went very quickly. The passenger side is about 1/4" lower than the drivers side, so tomarrow I'll tweak that and cut the ends off and make caps for them.
    1,258
    This has been a fun build, when I'm finished with the front I plan to make a rear also. To finish the front I have to cut off ends and make caps, cut in some fog lights, add a "baja" bar, mount some KC's and add recovery points. Still debating on a coating for it, I am torn between powder coat and spray on bedliner, I am leaning toward the bedliner only because I want to do my nerf bars also and I think the bedliner would be more durable....but who knows?
    Jul 2006
    1,508
    Very nice build!
    I think you should really consider the bed liner material.
    http://www2.line-x.com/nw/military.html
    Caution!
    720
    That is a nice bumper. How much do you think it weighs?
    Island Falls Maine
    562
    cooooooool
    l
    1,258
    Quote Originally Posted by kiwi View Post
    not sure, I'll try to rember to weight it when I remove it for final welding. I do know it's much heavier than the stock tin/plastic one!
    1,258
    pic update
    Nov 2008
    Roy, UT
    79
    very nice!!!!!!!!
    \\fshill\users$\d\Derek.Allen\Documents
