Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Feb 2010
    Ocean Springs, MS
    15
    the angle maybe for squaring pipe up to tack
    Nov 2009
    South Alabama
    257
    Quote Originally Posted by Vulcan Man View Post
    I like it,very functional. What is the piece of angle on the end for?
    justin is right, I put it on there for holding pipe or round objects strait or square. I also do mechanical on the side and it works well for electric motors or hydraulic cylinder work.
    Thanks for all the feed back guys. Jon
    "The only source of knowledge is experience." Albert Einstein
    Feb 2010
    Houston, Tx.
    378
    That is one sweet table! I can't tell you how many " portable" projects I've built that ended up over 300 lbs. It's not overkill; I just can't afford that much titanium!
