Results 1 to 2 of 2
    Default Replacing hose on smith jeweler's torch
    Has anyone had any experience with replacing the small torch hoses on the Smith jeweler's torch? The hoses are plastic with a woven seth around them and when it's cold the plastic tends to break because of tight spiral wrap that they are in. Has anyone replaced the hoses with small diameter vac. hoses?
    Dec 2005
    wisconsin
    836
    Quote Originally Posted by abprt View Post
    I think the new jewlers torch hoses are cloth woven over rubber, mine dont get hard at all in the cold. Might be worth just getting a new set.
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
