    May 2008
    Mpls, MN
    464
    Default Honda Engine Block - Cast Aluminum
    I got a call last week about welding an engine block. I assumed it was cast iron but figured I would check it out. Much to my surprise it was aluminum, this hole was formed when a boss that is cast on the block got pulled away by the exhaust manifold. I was originally going to weld a plate in, but once the boss was moved out of the way I decided to just weld it up. I welded the hole shut, cleaned it up and laid a second layer on top of it.
    Did this repair with my Dynasty 200, coolmate 1, 2% lanth 1/8", 150hz 72%. Total repair time from arrival to packed 2 hours.
    -Dan
    Owner
    DW Metalworks LLC
    Miller Trailblazer 302
    Miller 8RC Feeder
    Miller Passport Plus
    Miller Dynasty 200 DX W/Coolmate 1
    Hobart Handler 135
    Hypertherm PowerMAX 30
    Smith O/A Torch Set
    Plus more tools then my wife will ever know about....
    Dec 2009
    Northern California
    179
    NIce work!
    What was you cleaning method and how did you go about getting the build up done?
    Dec 2009
    722
    Nice job engnerdan.
    Did you burn the grease and oil out of it before welding it?
    May 2008
    Mpls, MN
    464
    The prep was wipe down the area with a lacquer thinner soaked rag, heat the area with propane torch, spray down the area with lacquer thinner and let dry and then heat with the propane torch once more.
    I then made a first pass all around the hole with 4043, then ground that down slightly to get rid of any of the crud that had floated to the top, then I built on top of that with 4043.
    -Dan
    Owner
    DW Metalworks LLC
    Miller 8RC Feeder
    Hobart Handler 135
    Smith O/A Torch Set
