Results 1 to 2 of 2
Hybrid View
    Dec 2005
    East coast
    206
    Default Aluminum Frame repair project
    Came across this late model sportbike frame. It has some damage.
    Some racers install Delrin bump stops to limit steering rage in order to prevent tank-slappers. When they do this, they drill a hole and mount it in a weak area of the neck, its maybe .100 thick AL cast. During a tumble, this one got whacked pretty good..
    Take a look at it and throw your 2 cents in. My idea is to strip, heat, bend the indented area out and then V/weld the cracks. An addtl reinforcement plate made from .120 wall 6061 in. Now from previous jobs, this cast al welds like crap, and I'm not sure it will come out winning any bueaty contests but should be sound..
    It's bieng built as a display, but may see some trackdays down the road.
    Have at it..
    Two Dynasty 350's with Wireless pedals
    Profax 250 weld positioner
    Bridgeport mill
    Logan Turret lathe
    RMD tubing bender
    Enco vertical saw
    Baileigh Auto cold saw
    IR 80 Gal dual stage compressor
    Misc Fab equipment
    Oct 2009
    254
    If I were doing it I wouldn't heat the damaged area since your likely to anneal it or over heat the area and ruin the aluminum. I would cut out a repair patch to go over the affected area and simply weld it into place making sure this is no running cracks from the damaged area possibly use LPI just to be sure.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
