    Oswego IL
    511
    Default ATV Snowplow-Poly Completed....
    Ok so I have been working less and less, and the wife has been working more and more giving me two probelms. First I have to much time on hands, my second the wife keeps putting more money in the savings....Anyhow I could not bring myself to pay for a plow for my rancher 350....so i made one so far I have 185 bucks in it, including the winch. I should only have about 125 in it but I bought some steel from mcmaster car and they are not cheap...
    We had snow today and I did 5.5 miles of plowing( I live in subdivision which has miles of walking ground which is never plowed.) So far my design is holding up well but I think I will end up boxing in the pivot arms, as the paint show they are flexing to much.....Anyhow I did build a poly plow and it sure moves snow nice....Next thing I want to do is to make the manual swing, power. I made it it have 5 postions....I did take some pictures...
    Kevin
    XMT 304
    Miller Spectrum 625
    Miller 30a spool gun
    S22a
    Miller Legend 302
    Lincoln LN25
    3,655
    Looks great. Sure wish i had it a few weeks ago when we got 2' dumped on us. Just for my sidewalks it would be perfect...Bob
    Nov 2008
    Kansas City Metro
    387
    Looks very nice, I really like the poly for the mold board.
    You might watch the mount point. I plow at a hospital, in a climate controlled cab that is. But when the shovel crews have trouble with the 4 wheeler we have to take a break from the lot and help them fix the little plow.
    There biggest problem is breaking the winch cable, yours looks like it mounts far enough forward to avoid over winding the cable. They also break the cable at the point where it repeatedly rolls on the fairleed roller. I suggested removing the roller and remounting the winch in a manner where the cable pays out in a straight line off the drum with no guides or rollers. Since its only for the blade, I see no need for the fairleed rollers.
    X-mas weekend they had the 4 mount bolts work loose just a bit and somehow they managed to bend the reinforcement behind the 4 bolts that it mounts to. Umm it may have been the curb they hit, probably didn't have it in low gear either.
    Snow just don't roll very good going slow.
    Like I said, Very Nice job. I wouldn't mind seeing a few more pics if you have them handy.
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
    Oswego IL
    511
    Default Thanks...
    Quote Originally Posted by tom37 View Post
    As for the winch, it has no rollers, infact its mounted inside the atv, and the cable pulls directly not against the rollers. The mount I made ties into the main frame of the atv, and is designed so the load is "pushed by the frame". As for plowing the poly blade does work well, the snow was very heavy and wet and it just rolled off.
    Kevin
    XMT 304
    Miller Spectrum 625
    S22a
    Miller Legend 302
    Lincoln LN25
    Rosetown, SK.
    514
    Good job & that beats the shovel by a mile.
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
