Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Dec 2006
    Traer, IA
    317
    Default Polaris Ranger Snowplow Build
    Just got done with this last weekend for a guy. Thought everyone might like to see some pictures.....
    Dec 2006
    Traer, IA
    317
    Default Plow pics # 2
    Here's some more....
    Dec 2006
    Traer, IA
    317
    Default Plow Pics #3
    last ones...
    Apr 2009
    Oswego IL
    822
    Default Nice just made mine....
    I dont think my atv could have lifted that one! That is built HD, curious to where you got the rotater for the blade? How much and how strong is it?
    Kevin
    Lincoln ranger 305g x2
    Ln25
    Miller spectrum 625
    Miller 30a spoolgun
    Wc115a
    Lincoln 210mp
    F550 imt service truck
    Dec 2006
    Traer, IA
    317
    The guy I built it for got the rotator off of eBay - about $400 shipped. I think you can probably find them cheaper. So far it seems to be holding up very well as we've had a bunch of snow. He's been pretty much plowing snow for all of his neighbors since I got it done so it's seen a lot of use already. I think my only concern with it is the size of the battery in the ranger. He may need to eventually get a bigger one or add a second.....
    Apr 2009
    Oswego IL
    822
    Default Battery Thought that might be a probelm....
    I wondered how much the battery would hold. I have considered using an air cylinder and a tank. Simply charge the tank go plow and return. I use my atv near my house, I already have a plow on my truck. How much did the blade weight after you were completed?
    Kevin
    Ln25
    Miller spectrum 625
    Miller 30a spoolgun
    Wc115a
    Lincoln 210mp
    Dec 2006
    Traer, IA
    317
    Quote Originally Posted by Tryagn5 View Post
    Kevin
    So far the battery is holding up, but it is pretty new too. Not sure how it's going to act once it gets a little more age on it. I know the winch on his 4 wheeler sure drains the battery down. Din't get a chance to weigh it. Got it done and mounted and he was here to pick it up before I even had a chance. The blade and the mounts one guy can handle, although it is tough. The power pivot weighs about 30lbs.
    Jan 2009
    Gold Hill, NC
    51
    Very nice Willy. Well thought out.
    Nov 2008
    Kansas City Metro
    387
    Great looking blade. I bet it holds up way better then the ones you can buy at the box stores.
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
    http://picasaweb.google.com/keesfriend Feel Free to Have a Look ( Just keep in mind I am an amateur )
    Sep 2006
    South Central Kansas
    58
    You did a great job, I am curious as to how thick your blade material is. I just finished taking my old riding mower snow blade that was 42" long and extended it out into a 60" blade to put in front of my Chuck Wagon. I used 1/8" thick plate and heated it in order to bow it. Got it done but took a little while and some persuasion.
