Page 1 of 3 123 LastLast
Results 1 to 10 of 30
    Noth Dakota
    505
    Cool I got caught today, a story
    Yes its sad but true. I was caught talking to a Side dump trailer needing cracks repaired in the tub. I thought I was out of ear shot when I said, "Hello Darling. Where you been?" to the trailer. "Looks like your tub needs some repair. Don't worry now you are with me. I'll cut out the bent stuff here, grind a bit here, weld some there, and with a bit of new metal yonder you will feel lots better". I heard another man say "Steve! You are talking to a trailer!!!". Without hesitation I turned and replied, "I know. They have feelings... just look at what happened to 'er you know." And so my sympathy for equipment that gets run hard, overloaded, and in general abused to get the job done has been exposed. OK time for work now.
    Vancouver, Washington
    51
    Wow I thought I was the only one who talked to my work. Sometimes if you listen real hard the arc answers back.
    Paul
    Honolulu, HI
    103
    Everybody talks to their work. But when you start hearing it talking back to you, it's time for an intervention.
    ****inson ND
    557
    Talking
    I "talk" (if you can call it that) to my work all the time! But I don't know if I could repeat any of it.
    Louisiana
    87
    Quote Originally Posted by Anti-GMAW View Post
    HA now that I can relate to.
    Aug 2002
    Appleton, WI
    207
    Default Talking to your work
    Loved the story. Sounds like me!
    I live in Cheraw, South Carolina
    112
    I am like Anti- Gmaw,
    Some of the stuff I say to my work is so bad it sometimes makes me blush
    6010
    Tucson, AZ
    37
    Default so true
    ha ha who hasn't talked to their work/projects in good or bad ways
    Vancouver BC Canada
    605
    I concur... It all depends whether I have hit my finger with the hammer, or accidentally touched the still smoking hot weldment that just turned from red to black...
    How does this sound: "C'mon you piece a sh t.... get in there!!!"
    or how about: "C'mon....! Co-operate with me Da mit!!!"
    and once in a while when all things fall into place...: "Shweeet!!!"
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    Fraser Valley, BC
    593
    Well at least your work is learning some new vocabulary.
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
