i found a great deal on some 10 c channel 15.3 lb /ft. I am thinking about useing it to make a low boy gooseneck trailer 32 ft long. I was thinking about just useing it and 3" c channel crossmembers every 18 in. with a wood deck. does this seem like it would be strong enough to hold two cars? and either 6 or 7k axles.
Results 1 to 10 of 27
Hybrid View
02-16-2010, 05:54 PM #1
- Jan 2008
- 11
gooseneck trailer design questions
02-16-2010, 06:05 PM #2
First thing the 3-inch C-channel cross members should be no more than 16-inch centers if using 2 x ? wood decking.
Caution!
These are "my" views based only on “my” experiences in “my” little bitty world.
02-16-2010, 06:11 PM #3
The 10-inch C-channel seems really light for a 32-foot trailer
, might want to think about a truss.
Caution!
02-16-2010, 11:56 PM #4
- May 2009
- The Colorado Gas Patch
- 184
I'm with sonora on the "Little Lite" comment.. the 10 x 15.3 C you mentioned is what I used on my tongue. I used a 12 x 19 I beam on the main frame and put a truss under it as well.. I am running 2 12K HD Disc brake axles under mine..
You mentioned 7k axles.. triple singles @ 3K / tire weight rating = 18K less approx 7k of trailer = 11K in cargo +/- what is on the truck springs..
The torque tube sonora mentioned will give you a better on highway handling ..
Here is my 42' GN it has the 1 1/2" T&G Rumber decking with the cross-members on a 12" CL:
Steve
Bobcat 250EFI
Millermatic 350P
Hypertherm 1250
A Bunch of tools
And a forklift to move the heavy stuff with..
Looking at CNC Plasmas
It's Miller Time - Get Back To Work!
02-17-2010, 01:49 AM #5
- Jan 2008
- 11
good comments, the light comments are my concern too. but when i search gooseneck car trailers it seems most of them are made out of 8 or 10 in c channel. so now im still confused
02-17-2010, 04:34 AM #6
Don’t panic yet!
Give us a little more information.
You say 32-feet long, is that total length from gooseneck receiver to the back? Or 32-feet of deck? Seems as most gooseneck A-frames are 8-feet long, and with a 60 / 40 ratio, you maybe looking at around 14-feet of span on your 10-inch C channel! Two 10”x15.3# C channel with a span of 14-feet are good for 12,800-pounds. See how it would help with a little more information? And a drawing, well can’t beat a drawing!
Changing your 3-feet span on the decking to 18-inches makes me look foolish for posting 16-inches max!
Caution!
02-17-2010, 10:57 AM #7
- Jan 2010
- 11
10" channel main frame 82" wide 32' with 3" crossmembers 16" spacing . Go with 7k axles 95" hub face 80" spring center [6k & 7k axles price are about the same] plus you will need the extra GVWR . IT will work.
02-17-2010, 11:06 AM #8
02-17-2010, 11:59 AM #9
- Sep 2005
- 4,246
I would take a look at some engineered units and copy.
02-17-2010, 02:03 PM #10
- Feb 2009
- Lodi, CA
- 1,126
yes, exactly, why re-engineer the mousetrap?????
