    A State of Confusion
    143
    Default Using available space on welding trailer to mount Vise
    Well being work not steady these days I have had allot of time on my hands
    My welding trailer is small and I donít have much room on it so I am using available space, I needed to have a vise on hand from time to time so was looking at the trailer to see where I could mount a vise so there were some pieces of square tubing welded to it by previous owner who had this little tote trailer I think was a sprayer at one time.
    So this is what I came up with not really a supper ideal but it will work for as often as I would need it.
    Jan 2010
    Pearland Texas
    14
    Nov 2008
    Kansas City Metro
    387
    Looks like it should work. Nice job.
    I have no experience with welding uni-strut. How strong is the joint after welding? Just curious here since I have access to 4 or 5 12 foot sticks of this if I want them. I was worried that it was a poor or low quality product as far as welding it.
    Hope work picks up soon. If you're like me, just start a large project at home and as soon as the house is tore to bits the calls will roll in like crazy.
    Tom
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
    2,971
    Tom,
    The piece on the trailer is not Unistrut
    http://www.unistrut.com/about/index.php?P=po_mf
    Looks like Square Fit telescoping tubing.
    Welds fine just remove the Coating- usually is Galvy Coated or Painted but it does come plain
    143
    It is Square Fit......and weld just fine.......once ya knock off the paint first
    Is strong for the most part but will find out sooner or later how much abuse it can take im sure it will take more than that ole vice can take
    Nov 2008
    Kansas City Metro
    387
    Thanks for the correction sir. That was a poor general statement on my part. At work we use both and some of our help cant seem to load up the right stuff unless we tell them its the uni-strut stuff with either holes in it or slots. I know its bad but thats what we put up with, I guess the good part is that they are at work every day and on time.
    I guess the good side is that you will use it right up to the day it starts to let go. And it may never fail. But if it does you can just put it back on.
    Have a good evening.
    Tom
