Results 1 to 5 of 5
Thread: grinder stand
    Apr 2008
    dallas,tx
    207
    Default grinder stand
    Finally got around to drilling the concrete and anchoring the grinder stand I built a while back. 3x3 x 3/16" square tubing as the base and 2.5x2.5x3/16" for the inserts. I had baseplates cut to match my grinder, vise and bender. Since i don't use the bender much, I may have to slide it out and turn it 90deg to complete a bend if need be but my soon to be built welding table has provisions for matching 3" tubing
    Miller 350P
    Miller Econotig
    Milwaukee Dry saw
    Evolution Dry saw (for sale)
    Scotchman 350 cold saw
    7x12 bandsaw
    1910 ATW 14 x 72 lathe
    fridge full of adult beverages
    Sirius radio
    www.snpequipment.com
    callouses and burns a plenty
    Apr 2009
    A State of Confusion
    143
    Nice job I like the set up might use your idea if some day I get a concrete floor if you dont mind.
    but that will all have to come later after I build an actual shop with some size to it just collecting materials slowly but surley for now
    Jan 2010
    Pearland Texas
    14
    Nov 2008
    Kansas City Metro
    387
    Stand looks good man, it should prove to be an asset to your shop.
    Tom
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
    http://picasaweb.google.com/keesfriend Feel Free to Have a Look ( Just keep in mind I am an amateur )
    Apr 2008
    dallas,tx
    207
    Thanks all. The work area is roughly 550 sq ft. I want to use the space as effectively as possible trying to keep only things in the shop that generate revenue
    Miller 350P
    Miller Econotig
    Milwaukee Dry saw
    7x12 bandsaw
    Sirius radio
