Results 1 to 10 of 10
    Default 42" pipe welding
    I recently started a job welding on 42" MILD STEEL pipe. What is the estimated time to weld a 42" asme full penitration. weld on pipe with stick and with mig?????
    Jul 2006
    1,508
    You left out a few details, like wall thickness for one. Fixed, or in a positioner / rollers?
    They won’t let you see the estimate? Have you ask?
    Caution!
    These are "my" views based only on “my” experiences in “my” little bitty world.
    Default it is fixed pipe...
    its schedule .40 they are using it to tunnel under the beltway in VA. It doesnt move you lay on ground to get the bottom and work your way around. then they push it in 20' and add another piece.
    Aug 2008
    Thetford VT
    64
    Schedule 40 has a wall thickness of .75. I assume stick on the root and wire after that?
    Chad
    Trailblazer 302
    Suitcase 12 RC
    S22P-12 Feeder
    HF-251-2
    Spoolmatic 30A
    Maxstar 200 DX
    Shopmaster 300
    S-22A Feeder
    Coolmate 3
    Trailblazer 250G
    Apr 2009
    KANSAS
    511
    Quote Originally Posted by Immortal welding 1 View Post
    Between 5 hours and 3 days. Depending on the welders skills, fit-up and working conditions.
    If they're riding you just tell'em "I'll be done when I get done, and not a minute F***ing sooner"
    They'll either back off or fire you. A win-win either way.
    '08 F-350
    Vantage 400
    SA-250
    SA-200
    Invertec V350Pro
    Invertec V205T-AC/DC
    Miller 12VS suitcase
    Miller spectrum 2050
    Pipe beveler's
    Track torch
    Feb 2010
    3
    Quote Originally Posted by Rig Hand View Post
    No Lie...one of my quotes..."I'm F***ing this monkey...you go siddown and listen to the monkey scream."
    Texas
    279
    Quote Originally Posted by W Welding View Post
    Chad, I believe the wall thickness is .375.
    L*S
    Aug 2008
    Thetford VT
    64
    The book I have states
    Schedule
    Std .375
    20-XS .500
    30 .625
    40 .750
    Mabey I'm reading it wrong
    Chad
    Trailblazer 302
    Suitcase 12 RC
    S22P-12 Feeder
    HF-251-2
    Spoolmatic 30A
    Maxstar 200 DX
    Shopmaster 300
    S-22A Feeder
    Coolmate 3
    Trailblazer 250G
    Dec 2008
    Arizona
    812
    Our welding procedures require a welding travel speed of 6-18 inches per minute. Given that a 42" pipe has a circumfrence of 132 inches (Pi x D), not counting grinding and rod replacement, etc. it would take 22 minutes per pass at 6 IPM. Given the wall thickness. it will probably take 5 passes, which would equate to 2.5 hours. I tend to think it would take closer to 4 given the real world situation of a bore pipe and all that is associated with that kind of work.
    If you get to MIG after your root and hot pass, you could probably do it in 3.
    EDIT: Never noticed the keyboard doesn't have a key for Pi.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Oct 2008
    Louisiana
    77
    Schedule
    Std .375
    20-XS .500
    30 .625
    40 .750
    Nope thats what it is!
    42" sch 40 is .750
    Miller Dialarc 250
    Miller Spectrum 625 X-treme
    Miller Bobcat 225
