Results 1 to 2 of 2
    Delmont, PA
    290
    Default PROJECT: Mini-Scroll Bender
    Hey guys,
    Here's a mini-bender I made that I keep in my mobile unit. It's made from a piece of 3"W X 1/4"T "C" channel with a vise lug welded to the bottom. I made it so I can slide the inner vertical post approx. 1" to adj. for thickness. It will also accomodate 4"W flat stock & I have bent 1/2" solid square with the O/A persuader. There are xtra tubes to slide over the fixed tubes to increase diameter. These are easy projects to make & will come in handy. Pics show the simpleness & ease to make.
    Denny
    A State of Confusion
    143
    Not a bad idea
    I made something similar basis but Iím not sure where it at this moment a Honey-Do project for the wife for bending and making spoon rings out of old silverware
    Looks like it bends well this forum is awesome and full of great ideas and craftsmanship
    CH!
