Results 1 to 10 of 11
    A State of Confusion
    143
    Default Home Shop Built T-Post Puller
    I’M sure some of you have already built on of these before
    I ended up needing a t-post puller on a fencing job and land owner said it would not work
    Thinking it was one of those flimsy store bought that end up bending or breaking after a few t-post
    Made this out of some old thick wall SQ tubing I had setting around after pulling 56 t- post with he decided he wanted it so I told him I would make him one and so I was thinking maybe I could sell a couple well so I advertised them and now have quite a few
    Of them Sold. Any way thought I would share this simple idea with anyone who wants to make one best to use 1-1/2“square tubing, 3” flat strap 6” in length, 4” flat strap 4x4 and 1-1/2” flat strap 6” in length all In 3/16th’s thick mild steel.
    Right now I am working on a 3 point attachment for my ford 8N tractor that will help one person doing it alone pull larger wood post I think will work well in our general sandy loam area.
    Any suggestions are appreciated.
    Last edited by CrazyHorse!; 02-08-2010 at 10:53 PM. Reason: forgot to ad the pic's LOL!
    Oct 2008
    Oregon
    193
    Looks good.
    My old friend uses his high lift jack.
    He also uses it to pull up utility poles.
    Millermatic 211 AutoSet w/MVP
    Century 110 volt 90/110 MIG-Gone to my son, in Texas
    Victor SuperRange OA
    Milwaukee Cold Cut Saw
    Milwaukee Portable Deep Cut Bandsaw
    Milwaukee Hole Hawg
    Jet Horizontal/Vertical Bandsaw
    Jet MD-18 Mill Drill
    Orbit Drill Press
    12 Ton Floor Press
    2002 E-350 V-10:
    1983 F-150 4.9L 6
    2004 Honda ST1300
    2007 Suzuki LTA400F Quad
    1997 Suzuki DR650
    Mid - MIchigan
    35
    I built one just a week ago. I've been using a chain on the end of it until I can get the hook piece made. can you give me the dimensions for that part that hooks the post? I have a picture of one that is a little heavier than yours but I don't want to make it any heavier than need be.
    143
    Default Hope this will give you an idea
    Quote Originally Posted by Mr Bill View Post
    Hi Bill hope this will help
    Jul 2007
    241
    What the heck is a T-post? Mike
    Mar 2009
    DFW, Texas
    71
    Sometimes they can be used as anchors, so that you can chain down the bucket of your utility tractor, and lift the rear end off the ground...
    Mid - MIchigan
    35
    thanks Crazyhorse - I"ll git er done tomorrow
    143
    cool post some pics when your done
    CH!
    Mid - MIchigan
    35
    got er done - just need to get pictures today sometime
    Mid - MIchigan
    35
    Finally - here's the pics. No paint yet but it's on the list. I thought it needed a little more support so I added the side brace. Thinking about adding a handle that will slip inside the larger tube to extend for more leverage. Some of the posts I tried pulling a few weeks ago took a little more than my 200+ lbs to lift out.
    Mind if I ask, what are you selling these for?
