I machined a plate to mount my 12 Volt electric winch on the tongue of my little trailer.
The mounting studs from the original plate are 3/8 propietary shoulder bolts. I drilled the 3/8 flat bar that I had laying around and machined enough room on the bottom, to accept the lock washer and about half of the nut. That allowed me to use the same bolts, even though the flat bar is thicker than the original plate.
I'm going to weld some 3 in x 1/8 flat bar to each side of the bottom of the plate that I made.
When I mount it to my 3 in. trailer tongue will 3/8 Grade 8 be sufficient to bolt through the plate and the tongue, from the sides?
I will use this 6000 lb (on a rolling load) winch to pull my 500 lb stacker onto the trailer.
Results 1 to 10 of 14
Thread: Bolt Size and Grade
02-08-2010, 05:44 PM #1
- Oct 2008
- Oregon
- 193
Bolt Size and Grade
Millermatic 211 AutoSet w/MVP
Century 110 volt 90/110 MIG-Gone to my son, in Texas
Victor SuperRange OA
Milwaukee Cold Cut Saw
Milwaukee Portable Deep Cut Bandsaw
Milwaukee Hole Hawg
Jet Horizontal/Vertical Bandsaw
Jet MD-18 Mill Drill
Orbit Drill Press
12 Ton Floor Press
2002 E-350 V-10:
1983 F-150 4.9L 6
2004 Honda ST1300
2007 Suzuki LTA400F Quad
1997 Suzuki DR650
02-08-2010, 05:48 PM #2
Caution!
These are "my" views based only on “my” experiences in “my” little bitty world.
02-08-2010, 06:00 PM #3
- Oct 2008
- Oregon
- 193
So then, a 3/8 grade 8 should be OK?
I notice they show 3/8 x 24.
Does that mean I shouldn't use coarse?Millermatic 211 AutoSet w/MVP
Milwaukee Hole Hawg
Orbit Drill Press
12 Ton Floor Press
2002 E-350 V-10:
1983 F-150 4.9L 6
2004 Honda ST1300
1997 Suzuki DR650
02-08-2010, 06:07 PM #4
I would use 3/8 x 16.
Caution!
02-08-2010, 06:48 PM #5
- Oct 2008
- Oregon
- 193
I would too, thanks.
Milwaukee Hole Hawg
Orbit Drill Press
12 Ton Floor Press
2002 E-350 V-10:
1983 F-150 4.9L 6
2004 Honda ST1300
1997 Suzuki DR650
02-08-2010, 08:09 PM #6
- Oct 2007
- Cave Creek Az
- 803
From the chart, and what you are saying you are going to pull I think a single #10 sheet metal screw would be the right size.
02-09-2010, 01:39 PM #7
- Oct 2008
- Oregon
- 193
Milwaukee Hole Hawg
Orbit Drill Press
12 Ton Floor Press
2002 E-350 V-10:
1983 F-150 4.9L 6
2004 Honda ST1300
1997 Suzuki DR650
02-09-2010, 01:51 PM #8
- Oct 2007
- Cave Creek Az
- 803
Ahh, come on, it was a joke! I'd use at least two for safety.
02-09-2010, 08:49 PM #9
- Sep 2005
- 4,248
You don't need fine thread or grade 8, 5 are plenty for most DIY work and preferable in a lot of cases. Toss the lock washer to get a full nut. Locks are not needed for most structural work, they been going by the wayside in a lot of applications.
02-09-2010, 08:50 PM #10
- Sep 2005
- 4,248
With correct design common grade 2 bolts will pull more than that winch.
