Results 11 to 20 of 20
02-08-2010, 06:52 AM #11
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
02-08-2010, 07:11 AM #12
- Sep 2005
- CT.
- 332
02-08-2010, 08:51 AM #13
I assume the plate you're talking about is the one in the post that you cut off
the manifold. Cutting the plates are not the big issue. Getting that shape into my cnc computer is the problem. I'm trying to find out how to do that without spending hours trying to clean the image and make it accurate. Is it worth doing all this plus shipping both ways for 5 plates. I'm working on it though as this will no doubt come up again.
NickNick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
02-08-2010, 09:40 AM #14
- Sep 2005
- CT.
- 332
It is actually the one I cut off and the thicker one I welded on. I have a cardboard/thick paper pattern of this. I will take a pic of the pattern tonite with length and width measurements. I do not know if you have a scanner for your CNC but it looks like it might fit in a larger flat bed scanner(not sure though). I know there are at least 5 out there that are cracked and there might be more. The person who I just did this for is going to post the fix up at some other site(s) he is on. I can drop ship you the material that I used for the plate I just did. Again, this would all depend on price of each to even see if it is a viable solution or not.
Thanks again.
T.J.Miller Dynasty 300DX
HTP MIG 240
HTP 380 Plasma
Bridgeport Milling Machine
South Bend Lathe
Etc. Etc....
tjsperformance.com
02-08-2010, 10:15 AM #15
TJS,
Here is the problem; when the image is scanned and I bring it into my CNC computer, it is a bitmap. Now, I have to trace that image and convert it to vectors. I need accurate, single line vectors. When the picture is scanned from a bitmap it has not a single; but double lines which are not accurate or smooth. It then takes a lot of cleaning up before I could even get to the cutting process.
You might try calling Kinkos or some place like that and ask if they can scan an image and convert it to vectors for you. All I have are small regular sized scanners and I couldn't do it in one piece anyway. I would have to scan it twice and merge it together accurately and then do a cleanup. That just leaves too much chance for error. Once I have an accurate file for the CNC we are ready for cutting. That only needs to be done once and we save that file. Then we can cut as many or as few as you want. I don't know what the cost will be until I run the file and see how long it takes to cut. I wouldn't think it would take more than 10 minutes to cut, though. Just a guess.
If Kinkos can scan it on a large scanner, change it to single line vectors and then print it out to verify the size and compare to your original pattern, then you are good. Then I can take those vectors and size it according to dimensions. My clipart comes as AI (Adobe Illustrated) and EPS (Encapsulated Postscript from Adobe Illustrated and Corel Draw) and I use the AI files
NickNick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
02-08-2010, 10:23 AM #16
- Feb 2007
- Near Dallas, TX
- 214
Where does the aftercooler go after this is plated over? I was thinking it fit in the gap between the intake and the V of the block. Is this a turbo conversion with bumper mounted intercooler? Does a 2001ish intake fit? Might be a bolt-on conversion to the turbo and front mount intercooler. Might have to buy a different throttle body and who knows what else
Dynasty200DX w/coolmate1
MM210
MM Vintage
Lincoln AC225
Victor O/A, Smith AW1A
Cutmaster 81
IR 2475N7.5FP
Evolution Rage3
Jancy USA101
9" South Bend
AEAD-200LE
02-08-2010, 11:59 AM #17
- Sep 2005
- CT.
- 332
02-08-2010, 12:37 PM #18
TJS
I called Kinkos and they said they can scan a pattern and vectorize it in the AI files I need to cut it out. This is in KCMO area but I'll assume any Kinkos
could do it. It's a $30 min and depending on how complex it may be more depending on time. If you have enough of these it would be worth them doing because they have large scanners and the proper software to do this correctly. Nick,Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
02-08-2010, 03:28 PM #19
- Sep 2005
- CT.
- 332
HTP MIG 240
HTP 380 Plasma
South Bend Lathe
Etc. Etc....
tjsperformance.com
02-08-2010, 05:37 PM #20
See post #15
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
