Results 11 to 20 of 20
    Raymore Missouri
    1,906
    Quote Originally Posted by TJS View Post
    Possibly for the surface grinder but I think wheel material would get imbedded in the aluminum which would be a bad thing. As for plasma cutting aluminum, it leaves a wierd cut on the kerf area. I still would have to grind it with a carbide cutter. CNCing a plate with a cutter would be the best.
    T.J.
    What did you decide to do?
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    CT.
    332
    Nick can you CNC router a plate. I need a price to make some more plates.
    T.J.
    Miller Dynasty 300DX
    HTP MIG 240
    HTP 380 Plasma
    Bridgeport Milling Machine
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
    Raymore Missouri
    1,906
    T.J.
    I assume the plate you're talking about is the one in the post that you cut off
    the manifold. Cutting the plates are not the big issue. Getting that shape into my cnc computer is the problem. I'm trying to find out how to do that without spending hours trying to clean the image and make it accurate. Is it worth doing all this plus shipping both ways for 5 plates. I'm working on it though as this will no doubt come up again.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    CT.
    332
    It is actually the one I cut off and the thicker one I welded on. I have a cardboard/thick paper pattern of this. I will take a pic of the pattern tonite with length and width measurements. I do not know if you have a scanner for your CNC but it looks like it might fit in a larger flat bed scanner(not sure though). I know there are at least 5 out there that are cracked and there might be more. The person who I just did this for is going to post the fix up at some other site(s) he is on. I can drop ship you the material that I used for the plate I just did. Again, this would all depend on price of each to even see if it is a viable solution or not.
    Thanks again.
    T.J.
    HTP MIG 240
    HTP 380 Plasma
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
    Raymore Missouri
    1,906
    TJS,
    Here is the problem; when the image is scanned and I bring it into my CNC computer, it is a bitmap. Now, I have to trace that image and convert it to vectors. I need accurate, single line vectors. When the picture is scanned from a bitmap it has not a single; but double lines which are not accurate or smooth. It then takes a lot of cleaning up before I could even get to the cutting process.
    You might try calling Kinkos or some place like that and ask if they can scan an image and convert it to vectors for you. All I have are small regular sized scanners and I couldn't do it in one piece anyway. I would have to scan it twice and merge it together accurately and then do a cleanup. That just leaves too much chance for error. Once I have an accurate file for the CNC we are ready for cutting. That only needs to be done once and we save that file. Then we can cut as many or as few as you want. I don't know what the cost will be until I run the file and see how long it takes to cut. I wouldn't think it would take more than 10 minutes to cut, though. Just a guess.
    If Kinkos can scan it on a large scanner, change it to single line vectors and then print it out to verify the size and compare to your original pattern, then you are good. Then I can take those vectors and size it according to dimensions. My clipart comes as AI (Adobe Illustrated) and EPS (Encapsulated Postscript from Adobe Illustrated and Corel Draw) and I use the AI files
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Near Dallas, TX
    214
    Where does the aftercooler go after this is plated over? I was thinking it fit in the gap between the intake and the V of the block. Is this a turbo conversion with bumper mounted intercooler? Does a 2001ish intake fit? Might be a bolt-on conversion to the turbo and front mount intercooler. Might have to buy a different throttle body and who knows what else
    Dynasty200DX w/coolmate1
    MM210
    MM Vintage
    Lincoln AC225
    Victor O/A, Smith AW1A
    Cutmaster 81
    IR 2475N7.5FP
    Evolution Rage3
    Jancy USA101
    9" South Bend
    AEAD-200LE
    CT.
    332
    Quote Originally Posted by Andy View Post
    The intercooler is the lower part of the intake. This is the upper I worked on.
    T.J.
    HTP MIG 240
    HTP 380 Plasma
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
    Raymore Missouri
    1,906
    TJS
    I called Kinkos and they said they can scan a pattern and vectorize it in the AI files I need to cut it out. This is in KCMO area but I'll assume any Kinkos
    could do it. It's a $30 min and depending on how complex it may be more depending on time. If you have enough of these it would be worth them doing because they have large scanners and the proper software to do this correctly. Nick,
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    CT.
    332
    TJS
    I will check with Kinkos. They are clowns here but we will see. What does an AI file mean. What extension do I need to tell Kinkos I want.
    Thanks.
    T.J.
    HTP MIG 240
    HTP 380 Plasma
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
    Raymore Missouri
    1,906
    See post #15
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
Tags for this Thread
