Results 1 to 10 of 12
    Feb 2010
    5
    Default my Syncrowave 350LX has Trouble
    I have a Syncrowave 350LX Serial # KJ286672.
    Welder welds great when stick welding but when you break the arc and set the stinger down
    Within 10 to 20 seconds the breaker in the breaker box trips.
    Any ideas what may be going wrong with this machine?
    What is the breaker size and what amps are you welding at? AC or DC, rod size.....
    a-
    8,281
    AS Andy said, it's likely that your breaker is too small and not handling the field surge after you break an arc
    Feb 2010
    5
    breaker size dual pole 50
    amps 95
    DC
    rod size 7018 - 3/16
    Deltaville, VA
    2,239
    What does your owners manual recommend for a minimum breaker size?
    125A?
    Don't just install a larger breaker using the existing wiring. The wiring needs to be sized according to the amp draw.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
    Feb 2010
    5
    125A?
    the max Recommended Circuit Breaker is 150 I dont have a minimum breaker size. the wire is 6 6 6
    600 volts
    8,281
    I guess you answered your own question then as 50 amps is barely enough power to run a little thunderbolt welder, let alone a biggun 350lx unit.
    50 amps isn't going to cut it. That's like jump starting your car with a lamp cord.
    I'm actually surprised it didn't trip the breaker sometimes when just turning the machine on from the transformer in-rush.
    As stated by Sundown, that machine likes over a 100 amp breaker and upsize your primary wire if needed.
    Good luck.
    A-
    2,949
    Default Only 95 Amps?
    Quote Originally Posted by Hiteker View Post
    amps 95
    DC
    I'm surprised you even got the rod to light at all
    A 3/16" 7018 needs 200-275 amps to keep lit
    95 amps is good for a 3/32" 7018 or a 1/8" 6010/11
    "Bonne journe'e mes amis"
    Oahu, Hawaii
    2,469
    Quote Originally Posted by ASKANDY View Post
    A-
    lol..........
    I'm not late...
    I'm just on Hawaiian Time
Tags for this Thread
