Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
    Nov 2009
    124
    Default Mitre Joint vs T Joint
    I have been working on a welding table plan and I was currious if anyone knew if there was a difference in strength between a mitre joint and a corner T joint. My suspicion is that the mitre joint should be stronger because there is more welded surface but that is more of a guess.
    Anyone know ?
    4,506
    Normally T joint is stronger but,,, usually any of them are strong enough. I don't like to cut miters so simple is good. Don't always use the strongest joint, but one that is adequate.
    May 2009
    Ontario, Canada
    101
    Mitres have an elegance to them, but are harder to fit up. I suspect a well made mitre may be marginally stronger than a well made T, but, the differences aren't all that great (maybe 1.41X in one direction). However, it is harder to fit up a good mitre than a T, so the T would usually win out. I go with what is easy to fab.
    Diversion 165
    Lincoln SP175T
    Ryobi Drill Press
    No Name Portable band and chop saws
    '97 Triumph Trophy 900 (3 cylinder, hence Triple!)
    May 2006
    180
    Properly welded, I don't think there is any difference between the strength of the two joint types.
    Miller XMT-350 CC/CV
    Miller S-22A wirefeeder
    Bernard 400A "Q" gun
    CK 210 & WP-18 GTAW torches
    Hypertherm Powermax 30
    Cave Creek Az
    1,097
    The T joint you are likely talking about is not a true tee joint, it is only a half a T (L???) I have seen many gates made with this joint and its weakness comes from the fact that the end of the tube is left open and it tends to rack easier. This is on thin wall tubing though. If you close the end then I think the joints would be near equal.
    Feb 2006
    Northern CA, Shasta CO.
    157
    wouldn't the shape make a difference?
    Cave Creek Az
    1,097
    The shape of what?
    2,949
    Quote Originally Posted by kraythe View Post
    Anyone know ?
    Both of these are "fillet" welds. Welded joint designs are selected primarily on the basis of load requirements.
    Your welding table is a "Statically Intermediate Structure," or a "Ridgid Frame" design.
    As with your trailer project you were contemplating, you'll need column anologies and simulated stress of applied loads to the elastic areas.
    Once these results are determined, then joint selection can be made.
    "Bonne journe'e mes amis"
    Feb 2006
    157
    Quote Originally Posted by walker View Post
    The shape of what?
    The shape of the pieces you are joining together. Hollow rectangle, angle, C channel, I beam, etc..
    Nov 2009
    124
    Quote Originally Posted by davedarragh View Post
    I think only the inside of the corner would be a fillet weld in a mitre joint. The outside corner would be just a corner weld (easy) and the tops would be only a butt weld. The inside weld would have to be a fillet weld.
    Sure to perform a pure analysis to say without a doubt that it is capable within x PSI I would need some fancy computer programs and math and possibly a few thousand in consulting fees. However, that doesnt necessarily have to be done for every project. Furthermore, that wouldnt answer the isolated question of which joint is usually stronger.
    There seems to be no consensus on the issue but it is interesting to think about. There also may be a difference between C channel, Tube and Angle on this as well.
