Results 1 to 10 of 13
    Feb 2010
    5
    Default Spot Welding with MIG
    I'm new to the site and have a question on Spot Welding with a MIG. I have a Miller 252 with the std. M-25gun and have been welding for about two years now. I need to do a lot of automotive sheet metal body part welding as a hobby (restoring my old car) and need some advice on doing "spot welds" with my MIG machine. Most of the steel I will be spot welding will be approx. 18 and 22ga.
    In doing "floor pans" in an older car, I have had a problem with burn through and irregular shaped welds, I think mainly because of inconsistency of thickness in the original sheetmetal due to prior corrosion, etc. I've tried moving in a circular pattern when doing the welds, but have had a hard time getting nice looking welds. Some good, some bad. I plan to order a spot weld nozzle. Maybe that will help?? I'm not sure of the "best" settings for voltage and wire speed and need some help. I could use some basic "tips" on the correct way to do a MIG spot weld, settings to use/try, methods, etc.
    Any help would be appreciated.
    Thanks. Harold
    Oct 2009
    306
    whenever I've done spot welds on a floor pan or auto body. I overlap the two pieces and punch holes about 5/16" in the top piece than just do a simple spot weld (correct stickout and gun angle than pull the trigger for a second or two) until the 2 pieces are welded to each other and the hole is filled nicely pretty flat. I usually run about 14- 17 volts and 200-220 ws. turn it down a bit more if that is to hot and your getting burn through.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Dec 2009
    Northern California
    179
    okie,
    If you have access behind the panels you are spot welding together, get yourself some copper plates or a copper plumbing cap to back up the hole and fill in the welds.
    I have and assortment of different diameter copper pipe caps with short pieces of pipe that I use a vicegrip to hold in place. I also have a couple of panel welding pliers that have a copper paddle on one side and the opposite end is forked and open around the hole to not only clamp the panels together and provide a backing to fill in the hole with weld. Finally, I bought a couple of pieces of copper sheeting in 1/16" to 1/8" and cut them into different shapes of strips and triangles and use them as backing, to fill in welds in impossible areas.
    Oct 2009
    306
    you can also buy spot weld vise grips that have a copper backing plate if your doing spot welds on an accessible edge.
    Jun 2009
    greenfield new hampshire
    889
    it takes more heat to burn the paint off than melt the steel, make sure both sides of the weld are clean, if you get it hot enough, the crap on the back side of the weld can be sucked into the weld ,pin holes, burnthru,s ect god luck
    Aug 2008
    Orange, TX
    1,217
    okie, Your MM252 has timer functions you would set to get the best spot weld results for particular materials. You set them by trial and error until you become familiar with what works and then tweek from there. If you're welding two different thickness materials you would weld from the 'thin' side.
    Timers to set would be Preflow, Spot Timer, Burnback and Postflow. For the best results you'll have to do some test settings on like material that is to be welded. Yes, you want to get any spot weld nozzles you feel you would need (straight, inside corner or outside corner) as they will allow for the consistancy you are and should be looking for.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Feb 2010
    5
    Thanks for the info. I tried to buy the flat spot weld nozzle for my 252, but Miller tells me it's discontinued. Do you know of anyone that carries these spot nozzles for my machine, or of a place that carries obsolete or discontinued Miller parts?
    Many Thanks.
    Jul 2008
    Delhi, Ontario:
    1,998
    Okie, You could also Pop Rivet the floor pans .
    ............ Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Aug 2008
    Orange, TX
    1,217
    okie, I suggest you check with forum member weldersales (Larry Burross). If he doesn't have any he may know of a source.
    If not, I would look at building your own using a standard nozzle as the basis. Slip a piece of appropriately sized copper pipe over, cut to length and shape the end accordingly for a straight, inside or outside corner. May have to turn down the standard nozzle OD or bore the pipe ID to fit.
    May be able to adapt another brand (Tweco, Bernard, etc) to fit too.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
    Oahu, Hawaii
    2,469
    Using a MM251, whenever we have to "weld" EMT tubing together to make a light duty frame or something (not my idea, just projects some of the school staff give us), we just use the mig and "spot weld"/ pull the trigger for a second and MAKE spot welds every 1 inch down the area neede to be welded. Then go back and spot 1/2 way of between those welds. Then go back and spot in between those welds. Then go back and spot between those welds. Do it until they are all connected. Once all those spots are all connected, then you can put a bead over that, because they is enough metal built up.
    have fun
    I'm not late...
    I'm just on Hawaiian Time
