Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Jul 2006
    1,508
    Maybe Harbor Freights sells these.
    http://www.youtube.com/watch?v=77IN6UhGSZE
    Caution!
    These are "my" views based only on “my” experiences in “my” little bitty world.
    Oct 2007
    Cave Creek Az
    803
    This bulldog is roughly 30" tall and across and is made of 10 gauge hot rolled. It is raised in the center about 2 1/2". I did it with a large rounding hammer while cold on a block of wood. I just raised one end and would hammer down on the section that was right above the wood, or set it between two blocks and hammer down in between them. Lots of lighter hits will net you a better shape than hard hits.
    Jul 2007
    241
    Quote Originally Posted by Chuck U&R View Post
    Grind the shape you want into a stump - like a bowl.
    Place steel over the whole, hit with hammer, repeat...........
    That seems like a pretty good idea,It seems like it would make it pretty easy if you heated the area dull red before hammering .A gas cylinder cap makes a nice round hammer with a handle welded to it.Mike
  4. #14
    Nov 2008
    Atl, Ga
    375
    Recycle the endcap from an old unserviceable propane or air tank? Just look for one with the approximate curve you want.
    2007 Miller Dynasty 200 DX
    2005 Miller Passport 180
  5. #15
    Nov 2005
    130
    "That seems like a pretty good idea" - Thanks.
    That's probably how they would do it here -
    http://www.metalmeet.com/forum/index.php
