I'm working on a project in which I have an 1/8 inch oval shaped steel plate that I need to put a slight convexity in from top to bottom and left to right. Don't have any special equipment though except a press. Any ideas?
Results 1 to 10 of 15
Thread: making a mild steel plate convex
02-01-2010, 05:45 PM #1
- Feb 2010
- 2
02-01-2010, 05:47 PM #2
- Jul 2008
- East Tennessee
- 609
You need to find someone with a heavy duty english wheel.
Dynasty 200DX "Blue Lightning"
Bernard 3500ss water-cooler
Rockwell vertical mill
Beverly Shear B-3
Beverly Shear JR
Home-made English wheel
Milwaukee Porta-band
" Sawz-all
Tennsmith 36" stomp shear
Fixer upper 1982 Lincoln sa200
02-01-2010, 10:40 PM #3
- Nov 2009
- 124
02-01-2010, 11:11 PM #4
An English wheel would be ideal as long as there's no scale on your material . . . unless the anvil (small wheel) is hardened. Are you near Dayton, OH?
How smooth / consistent does the surface need to be? You could also hammer the center of the plate against a hard surface, lots of small hits. That will thin the material, making it expand in length. Since the outside is constrained, the center will bow and create the concave surface you want. A torch will also work, but you need to shrink the outside of the plate, not the inside, or you will just cause it to buckle.
Jim
02-01-2010, 11:24 PM #5
- Jul 2007
- 241
How about putting it on a shot or sand bag and hammering to get the shape you want? Mike
02-02-2010, 04:37 AM #6
- Nov 2005
- 130
Grind the shape you want into a stump - like a bowl.
Place steel over the whole, hit with hammer, repeat...........
02-02-2010, 05:24 AM #7
02-02-2010, 03:39 PM #8
- Nov 2009
- 124
02-02-2010, 04:35 PM #9
Just get a bigger hammer!
http://www.ent.ohiou.edu/~raub/manuf...ng/forging.htmCaution!
These are "my" views based only on “my” experiences in “my” little bitty world.
02-02-2010, 05:39 PM #10
- Jul 2008
- East Tennessee
- 609
Beverly Shear B-3
Beverly Shear JR
" Sawz-all
