Results 1 to 8 of 8
    Question enclosed trailer
    I apperciate all the info and tips on the bbq/smoker. I am wondering if anyone knows what type of panels are used on the outside of enclosed trailers,and avaibility and cost or other options. i have also never seen the structure of one to know how they r built, would one b able to use those steel studs they sell at hm depot? for the outside framing and roll some tubing for the top and attach? would listen to any advise or links !! thanks in advance!!
    Jan 2010
    Mobile, AL
    8
    Quote Originally Posted by moneypitfootball View Post
    As far as the sides go. Mine is aluminum you should be able to get it in white. A buddy of mine re-skinned his a while back...
    Nov 2009
    Ohio
    118
    I know a few years back Northern Tool used to sell trailer plans. Dont know if they still do.
    Island Falls Maine
    562
    Quote Originally Posted by FastTenFive View Post
    I think aluminum would be your best bet
    Dec 2008
    Arizona
    812
    Quote Originally Posted by J C View Post
    Try this place for plans and info: http://www.trailerplans.com/index.ph...emart&Itemid=2
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Nov 2009
    Ohio
    118
    Quote Originally Posted by nocheepgas View Post
    I also know a guy who has a wheelstanding bus but he made the whole thing from scratch out of aluminum & I asked him how he got the radius in the roof & he told me he bought a coil & when he unrolled it there was the radius.
    Nov 2009
    Ohio
    118
    Cool. Do they have any plans for an enclosed with a single axle? Didnt see them if they did. I've always been told you can buy them for alot cheaper than you could build them.
    Jan 2010
    pennsylvania
    10
    Most enclosed trailers use .030" aluminum sheeting. some of the cheaper made trailers use .023" sheeting. ( would not recommend this) The trailers I build at work we use .040 sheeting. All of the above usually are"mill finish" on one side and a baked on enamel of varying colors on the front. .030 is more than sufficent. The wall studs are in most cases a very thin hat section wall stud or 1"x1 1/2" or 2" rect. tubing. The roof bows can be bought pre bent( also either tubing or a hat section). we also find that rounded roofs seem to have the most problems with leaking. we prefer a flat roof ( much easier to seal and stay sealed). hope this helps! Dont know where you are located but here is a link to our website. We might be able to help you out with parts. http://www.keystonetrailers.com
