Page 1 of 6 123456 LastLast
Results 1 to 10 of 58
    Nov 2009
    124
    Default Heavy Duty Welding and Cutting Table Design
    Greetings,
    I have been thinking of doing a heavy duty welding table that has more capabilities than my little metal table in the garage. My requirements were the following:
    * The table must be able to hold at least 2000# in addition to its weight. I work on engines sometime and if this was a general purpose table as well, it would be nice.
    * The table must have surfaces for cutting with my torch and plasma.
    * The table must have a funnel to catch sparks from cutting and channel them into a removable cleaning pit.
    * The table must have the ability to add clamps and other jigs easily.
    * The table must be able to take the heat of torch, tig and SMAW without significant warping.
    Below is a picture of some initial design ideas I whipped up in my CAD program. I created the table with 1/3 as a cutting surface and 2/3 as a welding and clamping surface.
    The cutting area is a grid of 1/4 inch by 3 inch steel bars set on the side in slots cut in the side rails. The idea is when a slat gets damaged by cutting it can be replaced. What isnt shown in the drawing is the funnel underneath. It will be a 4 sided funnel made of 12ga sheet and leading down to a collection pot.
    The welding area is composed of three 12 inch wide, 1/4 inch thick steel plate. Each plate is placed 2 inches from the previous to allow the insertion of bar clamps and so on. In addition, the plates are drilled through with 1/2 inch diameter holes every 3 inches so that stainless steel bolts can go through the surface to rig up clamps. I have thought of welding the surfaces to the frame but I think it would be better to fix them with stainless steel bolts so they can be replaced when needed.
    The top frame is .321 wall 4" by 1.721" C channel. I opted for C channel because it is provides a clamping surface as well as being less prone to corrosion than enclosed rectangular tube since air and moisture cant get trapped inside like a tube.
    The legs are currently designed as 4" x 5" x 1/4" rectangular tube though I might try to go C Channel here as well. I will have to brace them a bit more against racking other than the welds holding them. I havent put those braces in the drawing yet. The legs sit on heavy duty double locking casters from northern tool.
    The whole thing weighs, by my calculation of volume vs .35# per cubic inch of steel, 471# as currently designed which is making me wonder if I am getting too extreme in the engineering here. Perhaps I can use C channel with a shorter web (3" maybe) or thinner walls. The top surfaces do need ot be 1/4 at least for heat warping reasons since I use a torch a lot. However I am thinking the legs are perhaps too big and I could get by with C channel and a plate welded to the end of the channel to bolt the casters to.
    Comments?
    Apr 2008
    dallas,tx
    207
    471# is light. You didn't say if you were going to support the 1/4 pieces underneath. By looking at your drawing and the hole spacing, it looks to be about 36", I'd expect to see some bow with some weight on it unless supported. One of your requirements is the ability to hold 2,000#, the C channel frame and either leg design (with the bottom leg bracing) should be up to that task providing you add some crossmembers under the 1/4 pieces. I'd also move your C-channel inboard so you can clamp along the outside. The inner side of the C channel has a slight taper to it which could make clamping a PITA
    I am about to start my welding table using 1/2" for the top with slots cut in it to allow clamps as well. I figure I should be able to get a clamp on 70+ percent of the table. I hopefully will be posting pics in the next week or so of it
    Miller 350P
    Miller Econotig
    Milwaukee Dry saw
    Evolution Dry saw (for sale)
    Scotchman 350 cold saw
    7x12 bandsaw
    1910 ATW 14 x 72 lathe
    fridge full of adult beverages
    Sirius radio
    www.snpequipment.com
    callouses and burns a plenty
    Nov 2009
    124
    Quote Originally Posted by STRENGTH AND POWER View Post
    I am wondering If I need to brace the legs as well by welding cross members on them just above the casters. Probably wouldn't be a bad idea given that the table can roll.
    And the 1/4 inch plates are braced underneath with a single cross member in the middle. The problem with turning the C channels around is that it gives me limited surface to secure the legs to. Probably would be better to leave them as is and create an overhang (which I would have to do anyway if I turned them around.
    Nov 2009
    Charlotte NC
    68
    Default weld table?
    You guys building a welding table or a ram for car crusher?
    If enough force is being applied to steel pre weld to justify the beef ya'll are designing, you are gonna need a much larger surface area.
    Use square tube for legs, 3" or better,..frame top with angle or sq tube 2" to 4". Cope 6' channel on ends to drop in and be movable for the top.
    If more than this is needed, check your prep.
    Miller TrailBlazer 251NT
    Miller HF-250-1
    Miller Maxstar 150slt
    Miller ft peddles and thumb wheels
    Miller MM 212
    Lincoln power mig180c (two of)
    MM 252
    Miller Elite Dig
    Miller Pro-Hobby
    Nov 2009
    124
    Quote Originally Posted by wagin View Post
    2000# is nothing to laugh at. Stripping a truck engine out and placing it on the table is a lot of stress. What you described would bend and probably fail. Just do a 2000# load on your 2" tube over 5 feet in a deflection calculator.
    Apr 2008
    dallas,tx
    207
    Nothing wrong with overkill.
    Miller 350P
    Miller Econotig
    Milwaukee Dry saw
    7x12 bandsaw
    Sirius radio
    May 2009
    The Colorado Gas Patch
    185
    Over-Kill is cheap life insurance:
    Steve
    Bobcat 250EFI
    Millermatic 350P
    Hypertherm 1250
    A Bunch of tools
    And a forklift to move the heavy stuff with..
    Torchmate 2x2 CNC Plasma
    It's Miller Time - Get Back To Work!
    Nov 2009
    124
    Wow that is a **** of a table. is that 2 inch thick steel top? You would need a forklift to move that.
    Feb 2008
    Western NY State
    41
    Smile Steve;
    Thanks for the photo showing the holders for mig gun and plasma gun. I just printed that one so I can make similar ones for my welding table.
    Bill
    Miller Mig 130XP
    Linde VI206 W/Mig
    Miller Econotig
    L Tec Plasma PCM32i
    Pneumtic Forging Hammer 75#
    Mechanical Forging Hammer 65#
    Propane Forge
    Makita Chop Saw
    Bader 72" Belt Grinder
    Bader Knockoff 72" Belt Grinder
    Milwaukee Portoband
    Feb 2008
    Western NY State
    41
    Default Steve;
    Also I just noticed your 2 inch receivers under the table. My table is 1/2 inch plate, 4 foot square, with 3 inch angle iron legs. I was lucky enough to be given this gem which saw very little use. I have the two inch receivers on three sides of the table with a bunch of different fixtures that fit into them for quick change. When removed the table is clear and flat.
    I went a little further and made some smaller receivers for one inch square tube, using angle iron. With a little cleanup on the inside of the one inch tube, 3/4 inch square bar fits nicely inside of it. These smaller receivers I use for lights, bench grinder and vertical mount of portoband.
    Bill
    Miller Mig 130XP
    Linde VI206 W/Mig
    Miller Econotig
    L Tec Plasma PCM32i
    Propane Forge
    Makita Chop Saw
    Milwaukee Portoband
