Results 1 to 3 of 3
    Default New 165 start up
    Anyone know the details of the requirements for HF grounding, is it needed, what is the purpose?
    An intire page is devoted to it in the owners manual.
    That page is mostly a precausionary measure. Since that machine uses HF inpulse and only to start the arc, I highly doubt you will have any HF problems. HF can affect computers, phones and other electronic devices.
    That information is good to know if you are in an "electronic sensitive" environment. Labs, Nuke plants, Airports, Wife's TV
    Andy
    Jan 2010
    Medina, Ohio
    25
    I have my 165 on the other side of the wall (ie garage on one side of the wall family room on the other) from our TV/entertainment center and I've not had any issues.
    I know when I used to run a Syncrowave 250 that was not HF grounded it would "bite" you every once and a while. But being a sync HF ran 100% of the time.
    Hope this helps.
    Chris
    MM 175
    Diversion 165
