Results 1 to 7 of 7
Thread: Help with resto
    Island Falls Maine
    562
    Default Help with resto
    IM restoring my 85 high serria truck and I was kinda wondering if anyone has any advice on things that I should beef up or replace. Any and all advice is welcome. Thanks in advance.
    Dec 2008
    Arizona
    812
    Default 2 or 4WD?
    Either way, replacing the cab mounts is a must. Are you going down to the frame? Pretty good trucks to start with, plenty of parts availability, etc. I'd recommend Dynamat on the interior floorboards http://www.dynamat.com/products_auto...roduction.html and perhaps Lizzard Skin http://www.lizardskin.com/ on the undercarriage. I don't remember if the 85's had the improved hood or if they needed stiffeners to keep the hood from bending.
    Good Luck! Post Pics.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    1,882
    If it's 4wd then you need to brace up the frame where the steering box mounts. They sell a plate to weld on & you can also get a brace that bolts in behind the box (using the steering box bolts) & goes inwards to the center of the crossmember. This was a weak area especially if you lift it. FYI--85 body style had a good hood. Aftermarket sheetmetal parts are cheap & plentiful but find a place local as shipping will kill you on fenders & doors. Also I should have said almost all parts are available aftermarket. Just do a search on the web & you'll find a ton of suppliers for these trucks.
    1,882
    Almost all parts are interchangeble from 81 thru 87. I was never a big fan of those auto-locking front hubs. I would replace with a set of manual ones.
    Island Falls Maine
    562
    Thanks alot everyone I ment to say above that it is a 4x4. I bought 2 doors, 2 cab cornors, 2 rocker panles, 2 fenders, 2 fender wells, all OEM for $200 from my uncle All I need for the body parts is a 8' bed and tailgate. Thanks agen..
    Dec 2008
    Arizona
    812
    Quote Originally Posted by m.k.swelding View Post
    Are you restoring one or building it from scratch?
    130XP MIG
    Spectrum 375
    Island Falls Maine
    562
    building one i think
