Page 16 of 17 FirstFirst ... 611121314151617 LastLast
Results 151 to 160 of 167
  1. #151
    wisconsin
    113
    Quote Originally Posted by pepi View Post
    Finished the hand cart conversion, finally got the weather I needed to paint it.
    Attachment 31781
    Attachment 31782
    Attachment 31783
    Attachment 31784
    Nice job.
  2. #152
    Apr 2005
    Saskatoon, Saskatchewan
    220
    Almost done welding mine up.
    Welding Table Retirement - Mint Design
    Thermal Arc 185TSW, Lincoln SP135+, 4-post automotive hoist, 2x media blast cabinets, 50 ton press, 80gal air compressor, 4-1/2"x6" bandsaw, 4'x4' Torchmate CNC table with plate marker, Hypertherm Powermax 65 plasma cutter, ultrasonic cleaning stations
  3. #153
    Mar 2013
    Default Finally finished mine, including the paint
    I bought my welder about 3 weeks ago and used it to repair my elderly plow. I then decided I need some type of cart and walaa, I found this site. I looked at a lot of pics and decided to design my own. I drew it up, and its frame is built form 1x2 1/8" tubing. Got no fancy metal saws, so it was sawzall and angle grinder with cut off wheel. Anyway, what do you all think?
  4. #154
    Thumbs up
    some photos really cool! very interesting topic. thanks for all who post photos here.
  5. #155
    Apr 2005
    220
    The one thing that I really like about my welding table is the looped gussets. They allow me to slip whatever filler I need for the job at hand.
    TIG welding and CNC cutting - Mint Design
    You can see some ER70S-2 filler rods at the bottom. They are still in the PVC tube, the cap is taken off and the tube with the filler is slid under the table. When the job is done I just put the filler away. The next job may have some SS or AL filler put in it's place.
  6. #156
    Apr 2013
    3
    Default My welding cart attempt!!
    Here's my attempt at a welding cart that has about everything you need to make it convenient to store most everything welding related, I scratch built it from mostly stainless, only because I got the SS in a deal....I installed an electrical sub panel, all wired safely, to eliminate running multiple power cables across the floor, not the cheap way to do it, but it's much nicer. Power is fed from a 220V wall outlet in the garage, it splits to 110v at the cart panel enabling the use of the TIG cooler.
    It also has the air line plumbed for the plasma cutter that includes a filter. I would like to have a reel for an air hose but ran out of room. Overall a really fun build. If anyone would like to see the entire build thread, you can check it out at http://the510realm.com/viewtopic.php...114&start=1395 I warn you, there are lots of pics and pages to check out![IMG][/IMG][IMG][/IMG][IMG][/IMG]
  7. #157
    Illinois
    459
    Nice, great job. Perfect fit too. I don't know about the chippin hammer. That drawer is gonna get heavy after a few swings.
  8. #158
    Apr 2013
    3
    Nice one! I hadn't thought about that!! Thanks for the kind comments!
  9. #159
    3,654
    Like the cart all painted blue and the chipping hammer is different. I have about 100 of those springs that screw on 1/2" rod if anyone needs some drop me a pm...Bob
  10. #160
    Dec 2012
    Sweetwater, TX
    194
    Quote Originally Posted by goichi1 View Post
    The cart design looks really nice. I was wondering though, are you not concerned about the lack of air space behind the welders for air circulation? Page 19 of the 211 manual specifies 18" of space behind and in front for air flow. I believe the space requirement spec is the same for the Dynasty too, I know it is the same for my MM252.
    It mentions the air space on page 17 of the Dynasty 200 manual.
