I have a Airco 300amp Welder/Generator Hornet. The settings on the two switches on the control panel have faded and I can't read them any more. I believe the left switch(major amperage) has 5 settings and the right switch(fine setting) has 10 settings.
Can anyone tell what the left switch settings are left to right?? I believe the right switch is 0-10(counter clockwise), is this correct. Thanks for your help. This welder is similar to a 1978 Miller Big 20 but I haven't been able to fine a picture clear enough to figure out the switch settings.
01-25-2010, 12:32 PM #1
- Jan 2010
- Thrall, Texas
- 3
Control Panel Setting for Airco 300amp Hornet
01-25-2010, 02:14 PM #2
- Feb 2009
- Lodi, CA
- 1,126
You could look here, http://www.millerwelds.com/service/ownersmanuals.php, download the owner's manual for the Big 20, see if it's similar to what you have. If so, there will be some clear diagrams and/or descriptions in the pdf file.
01-25-2010, 03:40 PM #3
- Jan 2010
- Thrall, Texas
- 3
suggestion for user manual
I did that...and it talks about the settings without using any specific numbers and doesn't show any pictures of the front of the control panel....so I don't know if its 100,125,...300 or 100,150,200,...300...
01-25-2010, 08:10 PM #4
An Airco # is a bunch of #'s an letters, soooo if you posted a picture.....
01-25-2010, 09:20 PM #5
- Jan 2010
- Thrall, Texas
- 3
Picture of Airco 300 Welder
Picture of the Airco Control Panel that was faded over time until you can't read the settings.
03-27-2011, 12:27 PM #6
- Mar 2011
- 1
airco superhornet control settings
here ya go, this is from my airco superhornet 300.
