Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jan 2010
    ks.
    2
    Default how would u build a boat ?
    ok boys need some ideas.
    how would u build a cheap flat bottom jon boat.
    I am disabled vet short on money and know how.
    what would be cheap aluminum,tin or what would be good/cheap
    what kind of welder could i use ? / cheap ?
    the boat would need to be 16 foot and atleast 60 inchs across.
    Jul 2006
    1,508
    I think I’d be looking at marine grade plywood, and fiberglass.
    Material cost is less, and tool up will be a whole lot less!
    Caution!
    These are "my" views based only on “my” experiences in “my” little bitty world.
    Feb 2008
    miami
    261
    Default boat
    if i were you i would buy a used boat.
    Jan 2010
    ks.
    2
    man u taking all the fun out of it with wood.
    what about strong barn tin ?
    and a tig welder ?
    40 years ago we made one out of pickup hoods worked great .
    Jul 2006
    1,508
    Quote Originally Posted by RGO View Post
    and a tig welder ?
    You were the one wanting to do it on the cheap. There is nothing cheap / inexpensive about welding / metal fabrication!
    To start with: I’d draw up my design; get a parts breakdown with measurements. Shop for the best price to have all the material sheared.
    If you have your heart set on aluminum, look into a small 200-amp Mig machine with a spool gun.
    Caution!
    Nov 2006
    Lake of the Ozarks MO
    3,446
    All you have to do is order the material and cut out the correct shapes.
    Tack it all together first and then weld it.
    Your sizes chosen would be very nice. I would use .100 5052 aluminum.
    You would be fine using the MM211 with the spoolgun.
    You will probably have $2500-3000 invested by the time you are finished but when done you will still have the machine and can make more for you buddies.
    Make 3 and you should be able to just about break even
    Send pics as you go and keep us posted.
    BTW.....B.O.A.T. stands for break out another thousand, so forget cheap altho what I have shown you would be resonable and strong as he!! if you can fabricate worth a hoot
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    4,247
    I would look for used boat also.
    Salem ,Ohio
    3,658
    Cool
    Sheetmetal and some light sq tubing. But since i was a sheetmetal worker that would be like a giant piece of duct work with the top cut out...Bob
    Nov 2006
    3,446
    Steel would be a crappy material for a SMALL boat that needs to be moved by hand.... by the time you made it lightweight enuff to handle it would be flimsy. And it can rust unless you dipped in paint or galvanize afterward.
    That is why they make them out of aluminum.
    Fiberglass and wood are also much heavier as well.
    Big boats are a different story altogether.
    Miller WC-115-A
    Miller Spectrum 300
    SPEEDGLAS 9100XX
    Salem ,Ohio
    3,658
    Cool
    Yup you are right but when you put "U" and "cheap" in the same sentence thats how "I" would do it with what i have the resources for. Now if he said how should "I" build a good boat for x amount of bucks i would have a different answer. I worked in an old plant that made small steel boats many years ago and i saw how they were made so i could do one and it would be made from Galv sheet just like the duct work i welded for 12 hours a day at one time. Just my thoughts yours will be different.
    Of coures mine wouldn't be this pretty but some good reading here... Bob
    http://www.speedboatclassics.com/mul...teel_boats.htm
