I just finished welding the water jacket for the boiler. I had no major leaks but many pinhole leaks and i was wondering if anyone had any idea's on what i could put on the welds or in the water to stop the pinhole leaks. Thanks.
Results 1 to 10 of 10
Thread: Building and outdoor wood boiler
01-24-2010, 04:45 PM #1
- Jan 2010
- 1
01-24-2010, 04:50 PM #2
http://www.barsproducts.com/barsleaks_products.htmCaution!
These are "my" views based only on “my” experiences in “my” little bitty world.
01-24-2010, 09:38 PM #3
- May 2009
- The Colorado Gas Patch
- 184
Steve
Bobcat 250EFI
Millermatic 350P
Hypertherm 1250
A Bunch of tools
And a forklift to move the heavy stuff with..
Looking at CNC Plasmas
It's Miller Time - Get Back To Work!
01-25-2010, 05:40 PM #4
You might want to consider V- grooving the welds out and having a professional weld it.
You might also want to consider an unpressurized boiler if your not a pro.
Pressurized boilers can kill if you dont do things right.
I know a guy that had a portion of his blow up so he now runs it without pressure.
Good luck.
01-26-2010, 01:46 PM #5
- Oct 2007
- Edmonton,Alberta.
- 632
01-27-2010, 02:08 AM #6
Equipped with red and blue... and red and green!
01-27-2010, 03:18 PM #7
01-27-2010, 05:44 PM #8
- May 2007
- Alberta
- 135
Its a very good thing that u have the brains and the ***** to tackle a project such as a boiler. Based on whatever design you have created though, you have the potential for a very serious explosion and knowing the limits of your skill could save your life and or property. Have u installed any kind of pressure relief or is there any built in redundancy in your design. For your own safety and piece of mind, groove out and reweld or have it professionally welded.
owner of EVOLUTION WELDING
01-30-2010, 09:05 PM #9
- May 2009
- 184
Steve
Bobcat 250EFI
Millermatic 350P
Hypertherm 1250
A Bunch of tools
01-31-2010, 02:03 PM #10
Member
- Feb 2008
- West Bloomfield, Michigan
- 41
Loctite 290 (green wicking grade)
You can coat the inside and outside of the weld with loctite 290 as it will wick into the porosity - penetrate deep - and seal it up both air and water tight; but I would only suggest this in a maintenance capacity as a quick temporary fix on something un-pressurized. It will take boiling water temps no-problem but you throw pressure into the mix and it will blow out the weakest link.
You could drain it and dry out the welds by heating them up a little with a rosebud torch, then squirt on the loctite 290 and it will wick right in and seal up. Although, considering you are building something new, you should re-do it right.Last edited by t1113rs; 01-31-2010 at 02:11 PM.
XMT 350 w/ S-75 DXA Feeder
and a Bernard 300 gun
Optima Pulsing Pendant
XR-W wire feeder + Coolmate 4
with an XR-W Edge Gun
Passport Plus w/Spool Gun
Regular Passport
Trailblazer 301G w/Freak Box &
S-32P volt sensing wire feeder
Spectrum 1000 Plasma
Spectrum 375 Xtreme Plasma
Regular Spectrum 375 Plasma
Victor H315FC torch & accessories
Victor 100FC torch & accessories
Meco torch & accessories by Kent White
