Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Dec 2005
    San Diego, CA
    168
    Default Oscar Has A Hat On Always
    I believe this is Navy trick to remember the trig functions, I'll try to explain, hopefully without pictures.
    1. the trig functions apply to right triangles, (one 90 deg corner)
    2. the leg opposite the right angle is always the hypotenuse.
    3. from either the other 2 corners, the leg forming one side is adjacent
    4. the other is the opposite.
    with that in mind, take the first letter from the punch line to remember the trig function. sine = opp(Oscar)/hyp(Has), cos=adj(A)/hyp(Hat), tan=opp(On)/adj(Always)
    So if you can remember sin,cos,tan and the Oscar Has A Hat On Always, a $5 scientific calculator and a scrap of paper you're in business.
    For those more shop minded Hard is sometimes substituted with Hat
    Frank
    (aka Fred)
    MM200 (antique and still cook'n)
    Lincoln 160 buzzzzzz box - left to live with a nice youngster
    Dynasty 300DX
    Spectrum 625
    Chevalier Knee Mill - Bridgeport clone you idiot.
    Homebuilt tube bender - with home made dies no less
    Delta Drill Press & Grinder collection
    Needed - a bigger shop to use the stuff
  2. #22
    Dec 2009
    9
    Or this might work - Oley Had (Sine) A Hairy (Cosine) Old Arm (Tangant)
    Seemed to stick from highschool.
    Another one on litmus paper - BRA (Blue to Red = Acid)
    Hypertherm Powermax 45 PLASMA'r, Lincoln SP-100 MIGGER on gas, Lincoln 175 AC/DC Sq Wave TIGGER, Lincoln 225/125 AC/DC STICKER, 7" x 12" Horiz/Vert Band SAWER, Central 16" - 16 speed Drill PRESSER, Sanborn 3HP 20Gal Air COMPRESSOR, Dayton 9" disk - 6 x 48 Belt SANDER, Sears 8" Pedestal GRINDER, Victor O/A Torch BURNER, 150amp service to the 40'x64' Pole Barn - Priceless
  3. #23
    Jan 2008
    So. Cal
    100
    Here's an old school one for the boys
    Oscar Had Another Hard On Again
    Sine Cosine Tangent
    I forgot the one for girls
    Fab Tech
  4. #24
    Jul 2009
    New York New York
    46
    The one we learned in school is just some Indian name or something
    SOA CAH TOA something pronounced like "soo cah toe"
  5. #25
    Feb 2008
    859
    Quote Originally Posted by XLMFAB View Post
    Thanks for all the replies. Im trying to save to got to welding school so I can eventually answer my own questions.
    I think you'll be disappointed if you go into a welding program expecting to master geometry and trigonometry.
    As for remembering mnemonics for solving certain triangles... forget about words. Just learn the simplest trigonometric figure. The unit circle.
    The radius is 1, so the hypotenuse is always 1. Makes things easy. Note that the point on the circle has an X coordinate equal to the cosine of the angle. It has a Y coordinate equal to the sine of the angle. And the slope of the hypotenuse is analogous to the tangent of the angle... which is rise over run (everybody knows slope is rise over run - even roofers). And rise over run happens to be Y/X.
    The more you learn about trigonometry and higher math, the more you realize this circle is the ultimate cheat sheet. It tells you the formulas to everything.
  6. #26
    Island Falls Maine
    562
    We made a set one time but we made it with 16''x 16'' hardwood saw logs.
    Just an idea
  7. #27
    Oct 2008
    taxachussetts
    416
    from the ramps i see i hope your idea of a heavy truck is just a one ton? i think heavy truck I'm thinking 60,000 empty. it's great to see all the math but it needs to hold the weight. please post a pic if one ramp collapses. think about it.
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    suitcase x-treme 12vs
    miller 211
    evolution rage 2
  8. #28
    May 2008
    OCEANSIDE, CA
    123
    Quote Originally Posted by Fred Smith View Post
    Sort of... Law of Cosines and Law of Sines apply to solving remaining angles and lengths of non right triangles as well, but like Bodybagger said the unit circle is a giveaway for right angles. We always used the "Soak A toe A" SOH CAH TOA mnemonic.
    SOH = Sine = Opposite over Hypotenuse
    CAH = Cosine = Adjacent over Hypotenuse
    TOA = Tangent = Opposite over Adjacent
    It's really all about ratios just like the unit circle, but it's also about using what information you do have to solve for what you do not.
    DYNASTY 200SD
    COOLMATE 1
    MM140AS
    SPOOLMATE 100
    SPECTRUM 625 X-TREME
    SPECTRUM 125C
  9. #29
    Dec 2009
    7
    Default No trigonometry needed
    If you subtract 4 feet from the top and the bottom, you get a right angled triangle where the base is 8 feet (a) and the height is 2 ' 6" (b). The side you want is the hypotenuse (c). So, if you use the Pythagorean Theorem:
    (a*a)+(b*b)=(c*c) or (a squared) + (b squared) = (c squared)
    Then you get:
    c = square root ((a*a)+(b*b)).
    In this case, convert the feet to inches
    a=8*12=96
    b=2*12+6=30
    c=square root ((96*96)+(30*30))
    =square root (9216+900)
    =square root (10116)
    =100.5783 inches
    =8.3815 feet = approximately 8 feet and 4 37/64 inches (almost 8' 4 9/16")
    Hope this makes sense
Tags for this Thread
