Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Jan 2010
    Houston Tx
    6
    Question Finding the correct angle
    Im trying to build a set of ramps for a heavy duty truck to drive on. Im using 4" X 4" X 1/4 square tubing. the length is 12' and the height is 2' 6" with a 4' deck on top for the rear axles. I need to find the formula to achieve the correct angle for the incline. thank you in advance for any help.
    4'
    2' 6" █
    12'
    Jul 2006
    1,508
    Is this what you’re after?
    Caution!
    May 2008
    OCEANSIDE, CA
    123
    Delta=17 21'14"
    or the arctan of 2.5 / 8
    was my guess because it looked like the top was 4'
    otherwise it's the arctan of 2.5 / 12 = 11 46'06"
    DYNASTY 200SD
    COOLMATE 1
    MM140AS
    SPOOLMATE 100
    SPECTRUM 625 X-TREME
    SPECTRUM 125C
    Jul 2006
    1,508
    With 4-foot height.
    Caution!
    Jan 2008
    So. Cal
    100
    I Concur with UH60LCHIEF on the Delta
    The hypotenuse for 8’ x 2’-6” would be 8’ - 3 13/16” Delta of 17 21’ 14”
    The formula is the Law of Sin
    Fab Tech
    Fab Tech
    West Farmington, OH
    746
    You forgot to subtract his 4' deck from the 12' overall length.
    Blondie (Owner C & S Automotive)
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    Too many other tools to list
    03 Ram 1500
    78 GS1000
    82 GL1100 Interstate
    1,897
    Or you could just snap a couple chalk lines on the shop floor & measure it.
    May 2008
    OCEANSIDE, CA
    123
    Quote Originally Posted by FabTech View Post
    Fab Tech
    There's a whole pile of different ways to solve a trig problem. I just used ARCTAN theta (or Tan ^-1) of the ratio of the sides Opposite / adjacent, but law of sines does the trick just the same. You could use Pythagorean theorem to solve the hypotenuse and use any number of other functions as well. There's always like a million ways to skin a cat with a trig problem. Or like MMW said you could just snap a few chalk lines and break out a protractor. My calculator just happened to be sitting right there when I read it. Either way I hope that helps
    DYNASTY 200SD
    COOLMATE 1
    MM140AS
    SPOOLMATE 100
    SPECTRUM 125C
    Jul 2006
    1,508
    Quote Originally Posted by Blondie_486 View Post
    I was a little confused on exactly what he was trying to do! And the drawing wasn’t real clear, to me anyway.
    http://www.analyzemath.com/Geometry_...alculator.html
    Caution!
    Jan 2010
    Houston Tx
    6
    Default Ramps
    Thanks for all the replies. Im trying to save to got to welding school so I can eventually answer my own questions. The ramps have to have a 4' deck for the rear axles. Purpose being that the heavy duty truck is a industrial vacuum truck that has to offload into a 25 yard roll off container.
Tags for this Thread
