I do very little tig welding of carbon steel and for the size of the electrode can a coat hanger wire work ok or what should I be using
Results 1 to 8 of 8
01-22-2010, 12:34 PM #1
- Jan 2010
- 17
filler rod for tig welding carbon steel
01-22-2010, 01:07 PM #2
- Nov 2006
- Hampton, Va.
- 384
70S2 would be my suggestion.
Good luck,
Wheelchair
01-22-2010, 01:07 PM #3
You can get bare steel tig rod 70-S3 or 70-S6 in 1/8" and 1/32" wire. Its the same wire as mig wire but bigger dia...Bob
01-22-2010, 04:22 PM #4
- Nov 2006
- Hampton, Va.
- 384
01-22-2010, 07:52 PM #5
- Feb 2007
- West Farmington, OH
- 746
Whatever you do, do NOT use a coat hanger. Coat hangers are made of crappy steel. It's OK for a quickie exhaust pipe repair or something like that where strength of the weld is not critical, but for anything else use a 70S filler rod. They're not that expensive and even less if you buy a 10# box.
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
01-23-2010, 05:19 AM #6
- Jan 2010
- 17
Thanks, great info!,
All the best Bo
01-23-2010, 06:54 AM #7
01-23-2010, 05:13 PM #8
- Aug 2007
- IL.
- 8
70s-2 is good, but 70s-6 will run better. you'll get a cleaner puddle and better looking weld
