Results 1 to 8 of 8
    Jan 2010
    17
    Default filler rod for tig welding carbon steel
    I do very little tig welding of carbon steel and for the size of the electrode can a coat hanger wire work ok or what should I be using
    Hampton, Va.
    384
    70S2 would be my suggestion.
    Good luck,
    Wheelchair
    3,655
    You can get bare steel tig rod 70-S3 or 70-S6 in 1/8" and 1/32" wire. Its the same wire as mig wire but bigger dia...Bob
    Hampton, Va.
    384
    I have never heard of 1/32 wire. I think you meant 3/32 or 1/16th.
    Wheelchair
    West Farmington, OH
    746
    Whatever you do, do NOT use a coat hanger. Coat hangers are made of crappy steel. It's OK for a quickie exhaust pipe repair or something like that where strength of the weld is not critical, but for anything else use a 70S filler rod. They're not that expensive and even less if you buy a 10# box.
    Blondie (Owner C & S Automotive)
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    Too many other tools to list
    03 Ram 1500
    78 GS1000
    82 GL1100 Interstate
    Jan 2010
    17
    Thanks, great info!,
    All the best Bo
    3,655
    Quote Originally Posted by Wheelchair View Post
    Wheelchair
    Yes you are right. Thanks for the correction. I guess 1/32 would be mig wire...Bob
    IL.
    8
    70s-2 is good, but 70s-6 will run better. you'll get a cleaner puddle and better looking weld
