Results 1 to 8 of 8
    Jan 2010
    Default Shopping for a TIG
    Greetings
    I'm decent in conventional stick, and gas welding. I know nothing about TIG and want one. I restore motor bikes and to some extent cars (30 yrs). What is a great unit that will weld the thin to moderate gauges of aluminum and steel common to bikes (and car body), particularly to vintage machines? Its not uncommon for me to take the control gauges /switches apart and repair/break them.
    There a lot of deals out now, but my knowledge of advantages of machine features for my projects is next to nil. Lengthy details are welcome.
    thanks
    H2
    BTW :I am very open to a used unit. - issues related to such?
    Dec 2009
    Riverside, Rhode Island
    9
    Default Shopping for TIG
    I like your enthusiasm,TIG is a great welding process. Both major equipment manufacturers have a great deal of info on their web. I have two TIG units one is a 1960s H..... large 220 volt primary single phase unit. The bottom current level is not good for welding thin stock.This unit is great for aluminum .250 thick and up.Lots of current. The other unit is very portable M.....110 VAC primary and and I use it to weld stainless, steel tube and various low alloy steel tube. Keep in mind that TIG welding steel and TIG welding aluminum are quite different processes. Have fun.
    I started TIG welding when I was 15 on a maxstar with no foot pedal, 5 years later i can say that I learned a lot by using such a basic machine that was harder to use. For starting from scratch I would say get a dynasty but if thats out of the budge then something in the syncrowave family would be good, make sure you get all the options! Pulse welding is awesome once you get it adjusted to your liking and water cooling is very convenient as well. Good luck!
    Dec 2009
    Northern California
    179
    How2,
    Not sure what your frequency of use would be or your budget is.
    I would suggest you take a look at the new Diversion 180 due out in the late spring of 2010!
    If this is something you would be using at home, the dual voltage 110 /230 V is a nice feature and the simplicity of the controls may be nice for a set it and go situation. Also, since the case footprint is relatively small, it takes up less space and works well for the home DIY person.
    Now, just so know where I'm coming from, I have purchased a Diversion 165 for my personal use. However, I have a Maxstar and Dynasty at our shop and also have a Bobcat on hand. I have been using the Diversion more since it is easier to get situated with and just start and GO! Especially since I have been doing more Aluminum and Stainless.
    Nov 2009
    Palm Beach, FL
    3
    The Diversion is a great unit to start out with.
    Miller Diversion 165
    Miller Millermatic 251
    Miller Trailblazer 302 Diesel
    Miller Spectrum 2050
    Miller Digital Elite Helmets
    Miller Generator/Stick Welder circa 1982
    Hobart Beta-Mig 200
    Craftsman Stick Welder
    May 2009
    Ottawa Canada
    494
    Thumbs up Best tig of all!
    If you can fork out the cash,the Dynasty 200DX would be the very best you can get.For thin stuff you have pulse tig,for aluminium the thing is absolute perfection and it has enough kick to work thicker material too.Mine is three yrs old and has been flawless.
    Frank
    Millermatic 252
    Millermatic 180
    Hobart spoolmate 3035
    Digital Elite
    4,435
    Yes, the Dyn isn't cheap but the adjustable freq makes you feel like super hero.
    Feb 2010
    Houston, Tx.
    378
    Agreed Dynasty's are the Caddillac's. I used to have a Synchrowave 185 ( This was before the 200's came out.). It was a great machine, not portable, but great none the less. If you are doing Tig on steel and alum. you need something with a/c -d/c output. Either a Synchrowave or a Dynasty would be my choice.
