Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: Custom forklift
    Jan 2008
    Newfoundland, Canada
    66
    Default Custom forklift
    Well for those who have been asking about my old forklift project I'm happy to say that I got it completed. This ends a very long rebuild for me with this old forklift. I purchased it around this time last year and started in to rebuild it shortly after. I wanted it to be a fun project and to a point it was only for all the hard long hours it took to get it to this point.
    Basically everything had to be done. I had to remove all the paint, rust and crap others had done with it over the years before I could even begin to start the rebuild. the first thing I had to do was build a new engine hood for the beast. Toyota wanted over $3000. just for the hood so I fabricated the one you see on it now out of 1/8th plate. This one will be awhile before it rusts out.
    Basically I went right through the complete machine. New rings, bearings, lapped the valves and installed new valve stem oils seals. I rebuilt the mast. all new bearings in it as well and had to rebuild some of the hydraulic cylinders because they were leaking. Some of them had to even be re-chromed due to the pitting on them.
    After all that was done I sand blasted, primed and painted it. I fabricated the custom stuff such as the headlamp guards. Custom built the rear light bar and all the lights you see in it are strobes. I built sun visor as well and added some more aluminum plate to the sides to **** it out a bit. The top have a plexy glass top in it now. I added all new gauges and even fabricated new sections of the dash because it was in pretty bad shape. It even has air horns now along with chrome duel exhaust stacks. I had to design some custom adapters to get them to work on the lift but they sound nice so it was worth it.
    I removed the old Toyota charging system and it's external voltage regulator and installed a GM alternator with a built in regulator. Of course that's harder than it sounds because I had to make up new brackets to get it to fit. I also added a cool hook up to the engine cover that I can just plug my booster cables into so I don't have to pull up the lid to do it.
    Anyway there's much more to this story but I'm sure you'll see by the pictures there was a lot of work involved. One thing I did learn out of this. Never try and rebuild a forklift unless you have a forklift to help. These buggers a very heavy. I'm happy with the outcome. It's runs like new and will come in handy around the shop. Here's some photo's.
    Miller matic 350P
    Millermatic 252/Spool gun
    Miller Spectrum 875 plasma
    Miller Dynasty 200 DX
    Miller Coolmate 3
    Miller Elite ( INFERNO Digital)
    2008 Miller Trailblazer 302/Custom trailer
    Custom DX200 Crazy Cart
    Sofia 13 X 30 Lathe
    MODERN 10X50 knee mill with Fagor 40i DRO
    Craftex 30 Mill/Drill
    All this stuff below was done with Miller gear
    My YouTube vids:
    http://www.youtube.com/user/7863348
    Flickr photo's:
    http://www.flickr.com/photos/15602393@N05/sets/
    Jan 2008
    66
    New charging system installed:
    Some of the old wiring I removed:
    Booster cable hook up:
    Miller matic 350P
    Miller Coolmate 3
    Sofia 13 X 30 Lathe
    My YouTube vids:
    Flickr photo's:
    Jan 2008
    66
    More photo's.
    Miller matic 350P
    Miller Coolmate 3
    Sofia 13 X 30 Lathe
    My YouTube vids:
    Flickr photo's:
    Jan 2008
    66
    Making of a storage box and light bar. It took me almost two days to make the light bar and another to build the box.
    Miller matic 350P
    Miller Coolmate 3
    Sofia 13 X 30 Lathe
    My YouTube vids:
    Flickr photo's:
    Jan 2008
    66
    Miller matic 350P
    Miller Coolmate 3
    Sofia 13 X 30 Lathe
    My YouTube vids:
    Flickr photo's:
    Jan 2008
    66
    Considering I'll be using the lift around the yard either boosting vehicles or even towing them I realized I needed a storage box to put the cables and tow sling in so that's what I made yesterday. I had a bit of checkered plate left so I used that on the project. I also had to decide who I was going to mount the box and not wanting to drill or weld the counter weight I decided to machine a few parts for the lift holes and use two small pieces of threaded rod to hold them in place and then I could just simply bolt the box on the back and not alter anything. Here's how it ended up.
    Miller matic 350P
    Miller Coolmate 3
    Sofia 13 X 30 Lathe
    My YouTube vids:
    Flickr photo's:
    Jan 2008
    66
    Miller matic 350P
    Miller Coolmate 3
    Sofia 13 X 30 Lathe
    My YouTube vids:
    Flickr photo's:
    Jan 2008
    66
    This is the last of them!
    Miller matic 350P
    Miller Coolmate 3
    Sofia 13 X 30 Lathe
    My YouTube vids:
    Flickr photo's:
    alabama
    713
    Someone please give that man an award.
    XMT 350 cc/cv
    XMT 350 vs
    TRAILBLAZER 302
    MILLER DVI
    PASSPORT PLUS
    DYNASTY 200 DX
    MAXSTAR 150 STL
    HOBART CHAMP
    HF-251 BOX
    12-RC SUITCASES
    12-VS SUITCASE
    May 2008
    Troy, MI
    273
    Awesome job. Nice looking welds. I noticed that you welded the box without supporting your wrist or arms. I have found that I shake too much and need to support my arms or wrist for stability.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
