Thread: rusted artwork
    Umatilla OR
    12
    Default rusted artwork
    I was buying a chemical called scale gone 55 and it would take any scale off and make my projects rust quickly and evenly. I cannot seem to get any reply. could anyone give me a name & address of another product. thanks
    now in Orlando!!!!
    559
    Muriatic acid, avaliable at home depot and lowes, it will rust as drying,Paul
    More Spark Today Please
    Vancouver BC Canada
    605
    Default scale gone = muriatic acid....?
    Chances are they are one and the same, just different packaging.
    Muriatic acid is hydrochloric acid.
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    British Columbia
    162
    Post
    don't they use muriatic acid for cleaning driveways? thanks for the tip paul.
    Syncro250DX Tigrunner
    Victor set
    Elite auto-helmet
    Dewalt Bench grinder
    Mastercraft miter saw
    Mac air tools
    Mac hand tools
    Toothbrush
    pencil
    toilet paper
    Jun 2007
    arizona
    105
    be careful using the muriatic acid-don't breathe when using. i quit using it cuz i was tired of feeling like i was suffocating! the method i use is wash with oiler eater and rinse, spray on hydrogen peroxide and rinse. let dry, spray on a chemical i get from king architectural (i think it's amber rust but i would have to go check for sure) which turns the steel copper, keep spraying with water and let dry for a day or 2, then i spritz with krylon lacquer autumn brown which darkens the orangey-rust and also seals it (it does have a sheen tho). or use one of the powder coat "rust" finishes. if you'd like to see some pics of the finishes, let me know. cat
