Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    108
    Default Synthetic Oil in Trailblazer 302
    Weight of synthetic oil for Trailblazer 302 with Kohler Command 20 gas engine.
    Sep 2009
    11
    10-30 same as regular
    Jul 2008
    Delhi, Ontario:
    1,984
    Quote Originally Posted by Pat View Post
    In my old welder , Lincoln 150 I always ran 100% synthetic.
    In my new Lincoln Outback 185, They say No Synthetic at all. I use Castrol 10W 30 & in the Winter 5W30 Regular Castrol Oil !
    .......... Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Jan 2010
    Houston Tx
    I run Mobil One 10/30 in both my machines Bobcat 250 & 225. Over 2100 hrs on the 225 & 1500+ on the 250. I'm a believer in syns. Use it in my Harleys too. Wish I could afford it in my Powerstroke 15 qts...Ouch$$$$$$
    Mark
    Corunna Ont, Canada
    455
    Default Royal Purple
    Royal Purple for me in anything that takes oil...........
    TB302 10W30 all year
    Dodge Cummins 13 quart motor, rear end, trans, transfer case
    lathe in the shop
    lawn mower
    snowblower
    small gear box on wire striper
    After seeing what a difference that stuff make in the gear boxes at work I switched all my stuff over to Purple........
    Its not cheap, But its cheap insurance.........
    Railmen
    2007 Trailblazer 302G
    2004 Invision 354MP
    1999 60 series feeder
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    older Hobart hefty wire feeder
    Hyperthrem 600
    Maxstar 150S(such a cute welder)
    had and sold........
    2003 XMT 304CC/CV
    1947 Lincoln SA200G short hood
    1963 Lincoln SA200G
    1975 Lincoln SA200G(best machine ever had )
    1970's Lincoln SAE400G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    Oct 2009
    Quote Originally Posted by nfinch86 View Post
    .......... Norm
    I wonder why they say NO synthetics..... That is so strange as all of the other manufacturers highly recommend synthetics. HMMMMMMMMMM.........
    Jul 2008
    Delhi, Ontario:
    1,984
    Quote Originally Posted by Rickochet55 View Post
    Hi; I have no idea, that's what it said in the owners manual .
    No Synthetic Oil !
    I use only Castrol 10w30, regular oil .
    ............ Norm
    - LN-25 Wire Feeder
    - Spoolgun.
    - DeWalt Chop Saw .
    May 2009
    Ottawa Canada
    494
    Thumbs up Synthetic oil
    I'd run Mobil1 or comparable quality synthetic oil and be done with it.And just to give you an idea on how good it is,after 400 000kms+ on my motorcycle,the honing pattern is still easilly seen in the cylinders.Plus we run 5w30 Mobil1in the race bike cause we get 5mph extra on top speed over 15w50 and never broke because of oil yet.
    Frank
    I dont even want to try to calculate how mamy hours of running time that was
    Millermatic 252
    Millermatic 180
    Hobart spoolmate 3035
    Digital Elite
    Nov 2009
    spanaway,WA
    8
    Post
    i read somewhere that all mobil 1 is no longer FULLY synthetic. its like a 90/10 , blend.
    108
    Quote Originally Posted by koreanbeefcake View Post
    I suspect you are correct. I think I read where Mobil changed their base stock because of some loop hole that was opened when some consumer laws were changed that allow a "Synthetic Blend" to be called synthetic. I guess the word blend has to appear somewhere on the container. I wonder how many people get home and realize that "the bargain" they just got on synthetic oil is actually just a blend. I am curious as to how much synthetic has to be in it to call it a blend.
