Results 1 to 10 of 14
Thread: IceBoat
    Mar 2009
    Michigan
    138
    Talking IceBoat
    I have been working on an iceboat, almost complete! Should go 50+ MPH on a smooth Icy lake!
    Miller Syncrowave 200
    Miller Spectrum 875 Plasma Cutter
    Miller Milermatic 135
    Ridgid Drill Press
    Ridgid Chop Saw
    36" Metal Break
    Harris Toarches
    English Wheel
    Ingersoll Rand, 18.1 cfm Compressor
    30 gal. Sand Blaster
    Planishing Hammer
    150lb Anvil
    10" Swing Logan Lathe
    West Farmington, OH
    746
    Looks nice and like it's going to be a blast to ride. Too bad I have no knowledge of sailing so it wouldn't do me much good. I'd have to have one with a motor on it to be able to enjoy.
    What materials did you use to make the frame? Is that aluminum or powder coated or painted steel?
    Have you ever thought of mounting an engine and propeller on the rear similar to an everglade boat?
    Good job on the project!
    Blondie (Owner C & S Automotive)
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    Too many other tools to list
    03 Ram 1500
    78 GS1000
    82 GL1100 Interstate
    Mar 2009
    Michigan
    138
    I built the frame out of aluminum. Trying to stay away from engines, it makes it a cost free sport that way. Ice boats are known to go 5 times the speed ot the wind, so a 20mph wind = 100mph. No friction to slow you down
    Here is a picture of what I like to do in the summer!
    Ridgid Drill Press
    Ridgid Chop Saw
    36" Metal Break
    Harris Toarches
    English Wheel
    Planishing Hammer
    150lb Anvil
    Mar 2009
    DFW, Texas
    71
    I always found that Nacra's went faster with the bows fairly deep, rather than bow up...
    And with one of those, how can you look at yourself with a sunfish sail on the ice boat?
    Mar 2009
    Michigan
    138
    Quote Originally Posted by kbraby View Post
    Yes, True...But there is nothing better than putting one of your pontoons over a speed boater as you fly past them! and to see the looks on there faces
    I learned to sail on water with a sunfish when i was 8 so I figgured I would start small on the ice to. Dont want to get in over my head yet!
    Ridgid Drill Press
    Ridgid Chop Saw
    36" Metal Break
    Harris Toarches
    English Wheel
    Planishing Hammer
    150lb Anvil
    West Farmington, OH
    746
    Sails unfortunately for me would be a one way trip.... downwind then have to be towed back to point of origin. I think I'd have to build my ice boat with an engine just as my watercraft.
    Now what would really make the power boaters go nuts is if you could pull a water skier or two. Imagine the look on their faces seeing that!!!
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    03 Ram 1500
    78 GS1000
    Mar 2009
    Michigan
    138
    Quote Originally Posted by Blondie_486 View Post
    check out this link and you will see just That! i will have a boat like this someday
    http://www.youtube.com/watch?v=N6JiY...eature=related
    Ridgid Drill Press
    Ridgid Chop Saw
    36" Metal Break
    Harris Toarches
    English Wheel
    Planishing Hammer
    150lb Anvil
    Nov 2009
    Regina Sask. Canada
    15
    Default Ice boat
    This is your first ice sailer? I have sailed hard water off and on since 1984.Your rig looks light and should run ok. A couple of words of advice,longer runners to prevent side slip and sides at the seat. When cornering they will toss you off pretty quick. Nothing like holding on to the sheet while being dragged along the ice at 40 miles per. Great times if you have clear, safe ice. I have to look to find a pic of my bot and try to post it. Fred
    Feb 2008
    Guam
    177
    Knowing nothing about ice boats, I'm wondering how close to weather you can point with that lanteen type rig compared to a fractional rig. Looks like fun to me, 50 that close to the ground would be a rush for sure.
    Mar 2009
    Michigan
    138
    Quote Originally Posted by metalbender View Post
    Yes, this is my first iceboat. I will deffentaly take your suggustions. I basicaly built this from looking at a picture and no mesurements. I cant wait to give it a try.
    Ridgid Drill Press
    Ridgid Chop Saw
    36" Metal Break
    Harris Toarches
    English Wheel
    Planishing Hammer
    150lb Anvil
