Results 1 to 10 of 13
    Nov 2009
    22
    Default Another Cart Thread
    I couldnt stand the clutter any more. I allready had one of Millers decent mig carts but I knew I could make it better. LOL. I added a Cylinder rack to the back of it two hold 2 cylinders. One for 25/75% and one for 100%. I also ran a #10 power cord 18 feet long and put in two 220 volt receptacles. no more 6 foot cord for me! After that I added an top shelf for a 165 tig welder and a filler rod rack on the side as well as hose and cable racks on both sides and one on the back for the large power cord. One cord at the wall and power on the cart for both welders. In the pctures I have a 125 mini mig but the cart is made for the tig thats in the photo as well as a Hobart 187 hence the two 220 receptacles. What do you guys think?
    Nov 2009
    Montreal, Quebec
    49
    Thumbs up
    Quote Originally Posted by hotrodjohn View Post
    Nicely done hotrodjohn whit the base of ''decent mig carts'' and yes we can do it better to fit whit are need!
    XMT 304 cc/cv 208/480 volts
    Lincoln wire feeder LN-25 w/Contactor and Gas Solenoid, w/magnum 400 and 200 gun's (12 ft)
    Spoolmatic 30a w/Flex Head tube 10'' XRA
    Flexible Head Tig Torch w/Gas Valve (25 ft)
    Foot Control RFCS-14HD
    Side-to-side rotary-motion fingertip Current Control
    Miller process Selector Control w/external solenoid valve
    Stainless steel welding cart
    Makita LC1230 Dry cut saw
    www.ricau.ca
    South Carolina, Dixie
    515
    Smile
    Nicely done Hotrod.
    Mustangs Forever!
    Miller equipment.
    Mpls, MN
    1,790
    Look at those cute little cylinders.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    Nov 2009
    22
    I know those cylinders kind of suck. The rack should hold 80s ok though
    Mpls, MN
    1,790
    Just tease'n ya a little.
    If they meet your needs and don't run out too quickly for your taste - no need to sink money into bigger ones.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    Nov 2009
    22
    I have four like that. always one full set to the side
    Nov 2009
    22
    I do however feel that the postflow on he Diversion is a bit long in some cases. Wish I could turn it down a little. I run the argon at about 12-14 on the tig and it seems to run out twice as fast as the 25 on the mig from all the postflow
    Mpls, MN
    1,790
    I'd turn the flow down on the mig to 15cfh unless you're outside or have massive drafts in your shop.
    Mig arc time is so much lower for the same deposition as tig - that's why your gas lasts longer with it.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
    Island Falls Maine
    562
    as long as it works for you. good job.
