Results 1 to 10 of 12
    Nov 2009
    Montreal, Quebec
    49
    Default Floating Boat trailer
    This was the trailer a built for this boat and my concern was to get lower as possible, so a decentrer the axle and the frame. The result was very good, hitch it whit a car ( Vibe) a dint have to get to far down in to the water to let the boat go. What was funny is the trailer was floating when the boat is launch,,,becose of the frame are weldind seal and whit the tire full of air, it's float a bit
    XMT 304 cc/cv 208/480 volts
    Lincoln wire feeder LN-25 w/Contactor and Gas Solenoid, w/magnum 400 and 200 gun's (12 ft)
    Spoolmatic 30a w/Flex Head tube 10'' XRA
    Flexible Head Tig Torch w/Gas Valve (25 ft)
    Foot Control RFCS-14HD
    Side-to-side rotary-motion fingertip Current Control
    Miller process Selector Control w/external solenoid valve
    Stainless steel welding cart
    Makita LC1230 Dry cut saw
    www.ricau.ca
    Jul 2006
    1,508
    That tongue looks awfully long for the size of the square tube. Unless it’s some magical steel I bet it doesn’t last long if you go over many bumps. Might consider installing a piece of flatbar inside the tube to help matters.
    Caution!
    Nov 2009
    Montreal, Quebec
    49
    Wink
    tank's for your reply Sonora, and yes the tongue is long and just at the right longuer. At the end of it, when a hitch, it's weight near 45 pounds and perfect balance, whit 3/4 of the weight on the axle. The tongue is 2x2x1/4'' tick. A check before built this trailer whit other of the same size, and they all built whit this kind of 2x2 long tongue! Ricau
    www.ricau.ca
    Jul 2006
    1,508
    Might want to plug in some numbers to this calculator to see where you’re at.
    http://metalgeek.com/static/deflection.php
    Caution!
    Sep 2009
    South Carolina
    570
    Looks nice.
    Was it any trouble loading the boat back onto it?
    southern California
    1,783
    If I was going to use 2-by-something 1/4-wall tube for the tongue, I would have used 2x4 on edge, rather than 2x2. Other than that, the trailer looks nice.
    Millermatic175
    MillermaticPassport/Q300
    HTP MIG200
    PowCon 300SM, MK Cobramatic
    DialarcHF, Radiator-1
    Hypertherm PowerMax 380
    Purox oxy/ace
    Jackson EQC
    -F350 CrewCab 4x4
    -LoadNGo utility bed
    -Bobcat 250NT
    -PassportPlus/Q300
    -XMT304/Optima/Spoolmatic15A
    -Suitcase8RC/Q400
    -Suitcase12RC/Q300
    -Smith oxy/propane
    -Jackson EQC
    Nov 2009
    Montreal, Quebec
    49
    Looks nice.
    There was not much trouble loading back in to the trailer becose a don't go to far deep so it doesnt flot
    www.ricau.ca
    Nov 2009
    Montreal, Quebec
    49
    Quote Originally Posted by Desertrider33 View Post
    tank,s desertider and in this case, I needed to retrieve the hold tongue from the old trailer a rebuild, doesn't cost me a lot $ to have a nice low profil trailer for small run
    www.ricau.ca
    Mpls, MN
    1,790
    I'm not trying to say anything bad about your trailer, but have you pressure tested it for leaks?
    If it floats, but will slowly fill with water - then that means it will also slowly release that water and rust out rather quickly.
    For me, I wouldn't have it retain air at all. I'd put drain holes in the low spots and even in the high side on the tongue and any other "sealed" members. This way it will sink, but it will also drain, and the humidity inside the rails will equalize to that of the atmosphere the trailer is stored in.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    South Carolina, Dixie
    515
    Smile Trailer Harmonics
    Your will need to be aware of the harmonics associated with the length of the tongue. once the Oscillation has started it will be tough to stop.
    As I work full time in the Marine industry, I see a lot of trailers that literally fall apart from the inside out. Make darn sure the water can get back out of the trailer if it can get it. Drill the weep holes. Especially if it is going to see salt water. Otherwise your beautiful fabrication will be destroyed in just a couple of years.
    Mustangs Forever!
    Miller equipment.
