Results 1 to 3 of 3
Thread: Syncrowave180SD
    Stephens
    28
    Default Syncrowave180SD
    Anyone out there have one. I have had mine 4 years,never used it now warranty about to expire getting itchy?Are there any issues I should know about?
    Vancouver BC Canada
    605
    wow, how come so long to put it to use? I cant answer your question with regards to warranties, but im sure it'll be good to go. Miller makes a pretty good product.
    you could always sell it. Im sure that someone will buy it before the ad in the paper is two days old...
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    Ocean City, Maryland
    951
    I have one about the same age as yours...No issues and have used it alot. All TIG, never used it for stick, Great machine.
    Scott
    HMW [Heavy Metal welding]
