Results 1 to 8 of 8
Thread: Back Rack
    Jan 2006
    long sault ontario canada
    114
    Default Back Rack
    Anybody ever build a back rack for a pick-up like to get a few ideas Its going on a f150 xtended cab
    smokin ana grinnin for 20 years
    Owner MARKS MOBILE WELDING
    trailblazer 302
    hobart suitcase mig
    miller 30a al spool gun
    laramy plastic welder
    brocco cutter
    pipe beveler
    all walter hand tools
    100
    I've built quite a few.
    Here's a couple.
    Jan 2006
    Ontario
    17
    Default yup
    simple knock off.
    Jan 2006
    Antigonish, Nova Scotia, Canada
    33
    wldrman,
    Nice work, i especially like the patriots one. Maybe i'll buiild one for my truck and the when my dad sees it, he'll want one too.
    keep up the great work,
    Charles
    Oct 2005
    Calgary, AB
    52
    Default Just finished one
    I just finished the one that is on my '96 GMC 3500. If you give me some dimensions and an idea of what you're looking for, I might be able to do up a cad for you. Let me know.
    The attached is the headache rack, plus a rear rack a built to allow me to carry long (and heavy too) items above the cab and bed. I have HD bed rails (which I made) that the headache rack is welded to at the front. The back rack bolts onto the rails near the tailgate. When not in use, it bolts to the front against the headache rack. I'll try and get some pics of them on the truck.
    The difference between No One. and No. One is where you put the period. John Force
    Feb 2006
    Beresford N.B., Canada
    46
    Cool! Like that spider!
    Save our species! Lower metal prices!
    Jan 2006
    114
    Default your right
    2112 is right thats some pretty handy artwork how did you fit up your material ?your patterns look real profesional NICE JOB!
    trailblazer 302
    hobart suitcase mig
    brocco cutter
    pipe beveler
    100
    No special formula.
    I just measure my heigth, bottom and top width, lay it out on the bench to find my angles.
    I made the spider body from a block of aluminum. Hand ground all the details. The legs are individual pieces of .250 plate bandsawed and ground to suit.
    Usually I just blow up pictures on a copier, transfer them to my material and bandsaw cut the details from aluminum plate. The spider web is on my truck and can be removed for other details.
    The stars on the Patriot one should look familiar, they are a transfer of the Miller Welding star.
    Thanks for the positives! I spend a lot of time on these things.
