Results 11 to 14 of 14
    I Live in Ensenada Baja California, around 75 miles south of the border with San Diego
    34
    Powdercoating will be the easiest way to go, got to check with my customer and probably submit a sample.
    I will rather go for the more laborious method, the ones that let you learn something...or terribly waste your time ha ha ha
    Cat read your post on rusting metal and both you and millerman mention rinsing.
    With plain water?
    Snackers, that metallic finish web site is great, have you tried some of their products?
    A C T I O N ! ! !
    Jun 2007
    arizona
    105
    I don't know if powdercoat colors are universal but the "rust" ones I use most are "natural rust" or "roast". Also check out rustoluem textured spray paints in the multicolor - they have 2 rust colors that almost match the powder coat color "natural rust" if you need to paint bolts or touch up areas.
    Yes, rinse with plain water.
    What is the web site you are talking about with the metallic finishes? Snackers? Could not find.
    Thx, Cat
    34
    Hi cat. Saw pictures of your work it its pretty impressive, actually saw a couple of your pieces with that rusty look... awesome work
    A C T I O N ! ! !
    Jun 2007
    arizona
    105
    gman - thankyou. it's a great way to make a living! cat
