Results 21 to 30 of 33
Thread: Head Ache Rack on a Budget
01-04-2010, 09:17 AM #21
- Jul 2007
- 241
01-04-2010, 10:04 AM #22
- Sep 2005
- CT.
- 332
I really cannot remember as I write all the stuff down on my steel bench and then clean it off. But using angles: If the angle on the truck bed up right is 72 degrees then the opposite should be 108 degrees. 72 + 108=180.
However this means that each of the angles for the top piece should be
108/2=54 degrees each, but you are calculating from the included angle which is 90. So 90 – 54 =36 degrees. I think this is what I cut them for. This is why I did it in wood first.
T.J.Miller Dynasty 300DX
HTP MIG 240
HTP 380 Plasma
Bridgeport Milling Machine
South Bend Lathe
Etc. Etc....
tjsperformance.com
01-04-2010, 10:58 AM #23
- Jul 2007
- 241
Thanks for the reply, Laying out & calculating angles is an area were I could use improvement.Mike
01-04-2010, 05:40 PM #24
- Weldcraft WP26FV Tig Torch setup.
- Arcair- K 4000 CAC.
- LN-25 Wire Feeder
- Miller Econo Twin AC/DC High Freq.
- Lincoln Power Mig 180C
- Spoolgun.
- Horizontal Steel Band Saw
- DeWalt Chop Saw .
01-04-2010, 06:54 PM #25
Member
- Oct 2009
- Loomis, California
- 83
Truck Rack Project
T.J.,
Your project has got to be the best documented, photographed, and explained project I have ever viewed on this site!
You took the time to show every detail. You are indeed a very well qualified craftsman!
I enjoyed viewing the progress and reading your notes on how everything went together.
Congratulations! Excellent work!
Steve
01-04-2010, 09:31 PM #26
- Jul 2007
- 241
01-05-2010, 04:03 AM #27
Crawdaddy Hi;
Yes, The Bottom cut is at 18* to give you a 72* angle on the Upright !
On the Top cut each One @ 18* to give you 180* or Horizontal ! ( 36* Compound Angle )
Crawdaddy, in otherwards you make Three Cuts @ 18* Each , That's Per Side of the rack !
.............. Norm :
- LN-25 Wire Feeder
- Spoolgun.
- DeWalt Chop Saw .
01-05-2010, 06:22 AM #28
- Jul 2007
- 241
Thanks Norm.Mike
01-05-2010, 06:55 AM #29
Norm, You better go back to school as your dimensions don't work! If you cut them all at 18* then the top bar would be pointed up in the air as you only have a total of 54*. If the bottom cut was 18* then the total degrees needed at the top for a 90 is 72* which is 90* less 18* = 72*. So you would cut the top of the upright at 36* & the end of the cross bar at 36*. Adding it all up would give you 90 degrees. This would be for one side.
MM250
RCCS-14
01-05-2010, 07:18 AM #30
- Sep 2005
- CT.
- 332
Hehe. This is what I stated in my first post.
TOP Cut: 108*
But this is a compound miter cut on 2 separate pieces so 108/2=54* but you
need to subtract from the included angle which is 90, so 90*-54* = 36*, thus
both pieces will require a cut of 36*.
___________
72* / 108*
108*/__72*
Bottom Cut: 90*(included angle)-72*=18*(this is what the bottom tube is cut to)Miller Dynasty 300DX
HTP MIG 240
HTP 380 Plasma
South Bend Lathe
Etc. Etc....
tjsperformance.com
