It is just a bad idea!!!... over time the sand will erode the inside of the tank and fittings..(rather quickly)..... they will get thinner over time... at some point it might look perfect on the outside... while the inside is paper thin.... and will rupture at some point.... why endanger yourself or anybody else in the vicinity???.....
it is a pressure vessel that self degrades with use...
looks like darwin award material to me.... just do not take anyone with you....
how many times must this be pointed out???
Results 41 to 49 of 49
02-24-2012, 12:40 PM #41
- Nov 2003
- 2,019
The more you know, The better you know, How little you know............................. (Old Estonian Saying)
03-15-2012, 07:49 AM #42
- Aug 2008
- Riverside, NJ
- 7
03-15-2012, 09:23 AM #43
I weld pressure tanks almost everyday at work then they get hydroed or tested with air. I treat each one with respect that i test with air. Anything could happen and each one is looked at before i add the air. No hurrys. The next 4 tanks i am building are 26 feet long and 20" in dia. I only test them to 30 psi and then a dish soap water test on the fittings but thats a lotta air. We pressure tested gasoline barges on the Ohio River with 2# of air and it takes a while to fill them up to find leaks. A guy showed me how a 1/2# that was left in the barge and if you pounded the hatch open with a hammer it had so much force it would break your leg if it hit you, 1/2#. It opened my eyes to really pay attention...Bob
03-17-2012, 05:06 PM #44
- Sep 2005
- 4,247
You probably wont like mine then.
02-09-2013, 01:41 PM #45
Wow. It's been a loooong time since I've been here. Anyway. That blaster of mine has been used now for ten years or more. The only thing I've ever replace on it was the main hose. It's longevity has to speak for itself but its been flawless so just because I built it out of a propane tank do not mean its going to fail or be dangerous to operate. I have many safety features built into it such as a safety pressure relief valve and a dump valve.
This unit has hundreds of hours on it and its as good as the day it was built. Everything in my collection and including my commercial work has been done with this unit. You got to be kidding when you say this unit is dangerous. The unit only handles 100psi of air. If the side came out of it the only thing would happen is it would put sand into the air.
When it comes to my workmanship and my blaster design You sir don't know what your talking about. Simple as that!
http://www.flickr.com/photos/1560239...7608396649530/
Miller matic 350P
Millermatic 252/Spool gun
Miller Spectrum 875 plasma
Miller Dynasty 200 DX
Miller Coolmate 3
Miller Elite ( INFERNO Digital)
2008 Miller Trailblazer 302/Custom trailer
Custom DX200 Crazy Cart
Sofia 13 X 30 Lathe
MODERN 10X50 knee mill with Fagor 40i DRO
Craftex 30 Mill/Drill
All this stuff below was done with Miller gear
My YouTube vids:
http://www.youtube.com/user/7863348
Flickr photo's:
http://www.flickr.com/photos/15602393@N05/sets/
02-09-2013, 05:11 PM #46
- Feb 2012
- Wa
- 320
Wow. Such ignorance, only 100psi, haha. People have no idea how quickly things can go from fine to terrible.
02-10-2013, 08:03 AM #47
Wildfire.
Its not that simple. You have great pics and do wonderfull work for sure but please remember this is a public forum and some people aren't as gifted in the real welding world and think just because they have seen it here that they can do it. Maybe they can and maybe they shouldn't but its the internet and it has to be true, in some peoples eyes. I have seen air tanks come apart with just 100 lbs of air as it was my fathers just as he was done filling it with only 100 lbs, set it down and picked it back up and it blew. 6 weeks in the hospital and i will never forget that. Just my thoughts...BobBob Wright, Grandson of Tee Nee Boat Trailer Founder
04-02-2013, 02:34 PM #48
Bump
Acklands (Miller) N-250-HF
Lincoln 180c
SG100 Spoolgun
Lincoln Pro Cut 55 Plasma
O/A
04-09-2013, 04:11 AM #49
- Nov 2012
- 11
Hi, if anyone is so stupid as to see the posts and think "Hey I can do that too" who's gonna hold his/her hand the next time they cross the road. The whole point of posting your projects is to show the World what YOU have done, not suggest that that is the way to go about it. The point also is if you hydraulic test to 1-1/2 times the working pressure you are sure the job is sound. The point someone made about the container wearing away inside due to sand abrasion is probably not valid as the sand or abrasive material is just sitting there and not actively blasting the interior like the nozzle would get, and that applies to commercial tanks too that are made from the same thin metal as a propane tank, only they have a name attached to say it was made by whoever and tested hydraulically on such and such a date. If the hydro test fails due to poor welds, the water will only spurt out briefly. Ian.
