you do realize that we are talking about welding on a pressure vessel with incredibly questionable welds shown so far! please procede with utmost caution as you are creating a bomb for the hobbyist.
Results 21 to 30 of 49
06-18-2011, 11:04 AM #21
- Mar 2011
- torrington, connecticut
- 22
06-21-2011, 06:43 AM #22
- May 2011
- midwest
- 13
I've built a few of these back in the 80's. They are a very useful tool, especially prepping material for welding.
I extended the arm of the bottom feed valve so that it can be nudged w/ a foot or is easier to adjust while wearing gloves.
I have built a few of these and never used a rubber gasket. It could be that your pipe fitting warped from welding.
One needs to take precautions when cutting or welding on a propane tank; not for the amateur. Freon tanks also work and are more portable.
When using these you need a supply of DRY air. Moisture will cause sand to clog.
Keep in mind that there are inherent dangers in welding and danger in sandblasting.
Sandblasting can cause silicosis, and many novice types will not use proper ventilation/respiration precautions.
By the way, you'd be surprised at the damage you can do to equipment from dust particles floating in the air or how far the sand can travel and still damage automotive glass. If it can damage automotive glass..... it may also pose a rick to your eyes as well. Use proper safety equipment. You wouldn't weld without a welding helmet; RIGHT.... ?
A word to the wise....
WillyLast edited by ~willy; 06-21-2011 at 06:53 AM.
06-21-2011, 05:53 PM #23
- Sep 2006
- Abilene, Texas
- 639
06-22-2011, 04:27 AM #24
All of the import type models use an O-ring around the pipe filler neck for a seal. DRY air is more important for free following media.
Followed by a clear hood window and a great respirator.
As silicious effect on your lungs is cumulative, and it doesn't take much to cause you problems. And end up joining the oxy bottle brigade at Wally World.
And if you are using the deadman type import valves, HF is now selling the complete unit handle part for around $15.00 And if you are having a hard time finding the replacement rubber block with the alloy plate Tractor Supply sells them under their job smart brand.
Abrasive Blasting Deadman Valve with 4 Ceramic Nozzles HF Item # 92189
And one final thing, during the high humidity months, Don't fill the tank all the way up. And empty the media tank between uses if you won't be blasting weekly. As it will cake up at the outlet and in the fittings at the outlet/hose area.Last edited by PTsideshow; 06-22-2011 at 04:31 AM.
glen, If your not on the edge, your wasting space
08-22-2011, 09:01 PM #25
Member
- Feb 2008
- Western NY State
- 41
Sandblaster
I have a similar kind of rig and found that a tank pressure of 10-20 psi seems to feed a good quanity of sand. However it may be too much. What pressure setting are you using on the tank? Does the sand grit get into the feed valve you have on the tank outlet? I don't have a valve like that. Does it work well to control the amount of sand?
Bill
Miller Mig 130XP
Linde VI206 W/Mig
Miller Econotig
L Tec Plasma PCM32i
Pneumtic Forging Hammer 75#
Mechanical Forging Hammer 65#
Propane Forge
Makita Chop Saw
Bader 72" Belt Grinder
Bader Knockoff 72" Belt Grinder
Milwaukee Portoband
09-02-2011, 06:25 AM #26
- Sep 2005
- 4,246
09-03-2011, 05:59 AM #27
- Feb 2010
- 27
01-06-2012, 09:19 AM #28
Nice Bomb. With the quality of those welds, keep your children away from that unit. This is a PRESSURE VESSEL. Unless you've had training for welding on pressure vessels, I wouldn't dare weld on any pressure tank without training, especially a repurposed propane tank. At least get your bomb hydro tested, I doubt that those questionable welds will hold up and over time expect them to fail. It may work once, twice or even 10 times, but be prepared for that thing to blow up and when it does, the shrapnel flies, remember your dealing with COMPRESSED air If you don't care about yourself, that's ok, just don't subject your kids or friends to it. Do yourself a favour and go get a professionally made unit. The $100 that you're saving could cost you or your loved ones your an eye, an arm, leg or even your life. Don't mess with compressed air, even 10 psi can cause an incredible ammount of damage. And then come the lawsuits....
Acklands (Miller) N-250-HF
Lincoln 180c
SG100 Spoolgun
Lincoln Pro Cut 55 Plasma
O/A
01-06-2012, 10:33 AM #29
- Nov 2003
- 2,019
Doncha just love it when someone digs up an ancient thread and gets into a debate with it????...........
The more you know, The better you know, How little you know............................. (Old Estonian Saying)
01-06-2012, 01:50 PM #30
glad that YOU approve
Lincoln 180c
SG100 Spoolgun
O/A
